주요 콘텐츠로 건너뛰기
Flip Video Ultra USB Spring Replacement
필요한 것
  1. Flip Video Ultra USB Spring Replacement, USB spring: 1 단계, 이미지 1/1
    • Unlock the battery cover by sliding the switch to the unlock position.
  2. Flip Video Ultra USB Spring Replacement: 2 단계, 이미지 1/1
    • Remove the battery cover by sliding it down the camera.
  3. Flip Video Ultra USB Spring Replacement: 3 단계, 이미지 1/1
    • Remove the batteries
  4. Flip Video Ultra USB Spring Replacement: 4 단계, 이미지 1/1
    • Slide the black upper casing off from the device.
  5. Flip Video Ultra USB Spring Replacement: 5 단계, 이미지 1/2 Flip Video Ultra USB Spring Replacement: 5 단계, 이미지 2/2
    • Remove the six 1mm screws from the back and upper casing with the Phillips Head screwdriver.
  6. Flip Video Ultra USB Spring Replacement: 6 단계, 이미지 1/1
    • Remove the top casing from the bottom to reveal the inner circuit board.
  7. Flip Video Ultra USB Spring Replacement: 7 단계, 이미지 1/2 Flip Video Ultra USB Spring Replacement: 7 단계, 이미지 2/2
    • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
    • Remove the six 1mm screws with the 1 Phillips head screwdriver.
  8. Flip Video Ultra USB Spring Replacement: 8 단계, 이미지 1/1
    • Gently separate the circuit board from the casing.
  9. Flip Video Ultra USB Spring Replacement: 9 단계, 이미지 1/1
    • Using the Phillips head screwdriver, disconnect spring from the plastic nubs.
결론
Nathaniel Ruf
회원 가입일: 10/18/16
514 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 5-7, Martin Fall 2016 UMass Dartmouth, Team 5-7, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G7
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 145
