주요 콘텐츠로 건너뛰기
Flipper Zero iButton board Replacement
필요한 것
    • Go to Main Menu > Settings > Power.
    • Select Power OFF.
    • Alternatively, you can press and hold the Back-button for around 10 seconds.
    • Confirm by pressing the Right-button.
  1. Flipper Zero iButton board Replacement, Remove the microSD card: 2 단계, 이미지 1개 중 1개
    • Eject the microSD card by pressing it with your fingernail.
  2. Flipper Zero iButton board Replacement, Remove the screws: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Phillips #0 Screwdriver
    $5.49
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
    • Be careful, the screws are quite easy to strip.
  3. Flipper Zero iButton board Replacement, Open the back cover: 4 단계, 이미지 3개 중 1개 Flipper Zero iButton board Replacement, Open the back cover: 4 단계, 이미지 3개 중 2개 Flipper Zero iButton board Replacement, Open the back cover: 4 단계, 이미지 3개 중 3개
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
  4. Flipper Zero iButton board Replacement, Seperate the chassis from the top cover: 5 단계, 이미지 2개 중 1개 Flipper Zero iButton board Replacement, Seperate the chassis from the top cover: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    $5.49
    • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
    • Once the screws are removed, separate the chassis from the top cover.
  5. Flipper Zero iButton board Replacement, Disconnect the battery: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Spudger
    $3.99
    • Disconnect the battery by carefully prying the connector with a Spudger and pulling it out.
  6. Flipper Zero iButton board Replacement, Disconnect the ribbon cable: 7 단계, 이미지 2개 중 1개 Flipper Zero iButton board Replacement, Disconnect the ribbon cable: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    iFixit Opening Picks (Set of 6)
    • Disconnect the small ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
  7. Flipper Zero iButton board Replacement, Remove the iButton board: 8 단계, 이미지 2개 중 1개 Flipper Zero iButton board Replacement, Remove the iButton board: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    $5.49
    • Unscrew the short screw holding the iButton board in place using a PH0 screwdriver.
    • Once the screw is removed, carefully remove the iButton board.
  8. Flipper Zero iButton board Replacement, Remove the cable from the iButton board: 9 단계, 이미지 2개 중 1개 Flipper Zero iButton board Replacement, Remove the cable from the iButton board: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Spudger
    $3.99
    • To disconnect the flat cable from the iButton board, use a Spudger to carefully release the lock by pulling the latch up.
    • Once the connector is unlocked, gently pull the cable out of the connector.
결론
작성자
1다른 기여자 명과 함께
Sebastian
회원 가입일: 08/19/18
31,157 평판
안내서 71개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 40
전체 시간: 1,896
