소개
Over time, the hose on your steel floor drive pump may wear or puncture. Use this guide to install a new hose.
필요한 것
Use a pair of pliers to loosen the hose pinch by turning it counterclockwise a couple of turns.
Continue to loosen the hose pinch by hand until it comes free from its threads.
Slide the hose pinch down the tube so that it does not interfere with removing the hose.
거의 끝나갑니다!
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
