주요 콘텐츠로 건너뛰기
Fluance RT83 Belt Replacement
필요한 것
  1. Fluance RT83 Belt Replacement, Belt: 1 단계, 이미지 1/1
    • Unplug the turntable.
  2. Fluance RT83 Belt Replacement: 2 단계, 이미지 1/1
    • Lock the tonearm in place with the tonearm clip.
    • If the tonearm is not locked in place, it could move around and potentially damage the needle
  3. Fluance RT83 Belt Replacement: 3 단계, 이미지 1/1
    • Lift the rubber mat and place it to the side.
    • The rubber mat should come off easily, as it is simply resting on top of the metal platter.
  4. Fluance RT83 Belt Replacement: 4 단계, 이미지 1/1
    • Unhook the drive belt from the motor pulley.
    • The drive belt is carefully wrapped around the motor pulley, so it is important to unhook it gently.
  5. Fluance RT83 Belt Replacement: 5 단계, 이미지 1/1
    • Remove the drive belt from the metal platter.
  6. Fluance RT83 Belt Replacement: 6 단계, 이미지 1/1
    • Grab the new drive belt.
    • Wrap the new drive belt around the motor pulley.
    • Note: When reassembling the turntable, don't forget to wrap the new drive belt around the motor pulley.
  7. Fluance RT83 Belt Replacement: 7 단계, 이미지 1/1
    • Once your drive belt is hooked around the motor pulley, continue wrapping the drive belt around the entire metal platter.
    • If you are having difficulty wrapping the new drive belt around the metal platter, go very slowly and gently. Patience may be required for this step.
  8. Fluance RT83 Belt Replacement: 8 단계, 이미지 1/1
    • Make sure your drive belt is flush against the platter.
    • It is very important there are no twists in your drive belt.
  9. Fluance RT83 Belt Replacement: 9 단계, 이미지 1/1
    • Give your metal platter a gentle spin clockwise.
    • When spinning, the platter should continue to spin for a few seconds on its own.
    • If your metal platter is able to spin with the new drive belt attached, you have successfully installed your drive belt.
  10. Fluance RT83 Belt Replacement: 10 단계, 이미지 1/1
    • Place the rubber mat back on top of the metal tray platter.
결론
Test by playing a record.
Austin Daniel
회원 가입일: 09/20/23
181 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 32
전체 시간: 261
