주요 콘텐츠로 건너뛰기
Fluke 77 Series III Battery Replacement
필요한 것
  1. Fluke 77 Series III Battery Replacement, Front Panel: 1 단계, 이미지 1/1
    • Be sure any test leads are out and the multimeter is off before opening the device.
    • Turn the multimeter so it is display side down.
    • Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
  2. Fluke 77 Series III Battery Replacement: 2 단계, 이미지 1/1
    • Use your Phillips #2 Screwdriver to remove the four black 21 mm Phillips #2 screws.
  3. Fluke 77 Series III Battery Replacement: 3 단계, 이미지 1/2 Fluke 77 Series III Battery Replacement: 3 단계, 이미지 2/2
    • Turn the Fluke 77 Series III Multimeter back over so that it is display side up.
    • Pry the front panel from the back panel at the seam.
    • If the front panel does not come off easily, move a plastic opening tool along the seam until the panels separate completely.
  4. Fluke 77 Series III Battery Replacement, Battery: 4 단계, 이미지 1/2 Fluke 77 Series III Battery Replacement, Battery: 4 단계, 이미지 2/2
    • When doing this next step, make sure to remove the battery slowly, so you don't damage the wires connecting the battery to the device.
    • Locate the 9V battery in the lower right corner of the device.
    • Pull the battery out of its terminal.
  5. Fluke 77 Series III Battery Replacement: 5 단계, 이미지 1/2 Fluke 77 Series III Battery Replacement: 5 단계, 이미지 2/2
    • Only pull on the metal snaps and battery. Pulling the cords may damage them.
    • Detach the two metal snaps from the battery.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Jessica Bombardier Shaw
회원 가입일: 01/29/14
1,012 평판
안내서 7개 작성하였습니다
Cal Poly, Team 2-10, Amido Winter 2014 Cal Poly, Team 2-10, Amido Winter 2014 회원
CPSU-AMIDO-W14S2G10
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Easy to understand and all went well!
petruskewichw - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 31
30일 전: 115
전체 시간: 19,214
