이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This is a relatively quick and easy guide that shows how to replace the Fluke 77 Series III Multimeter LCD Screen Cover. The screen cover is the transparent plastic part that protects the LCD (display) of the Fluke 77 Series III Multimeter.
필요한 것
Turn the multimeter so it is display side down.
Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
Hold the front panel with both hands.
Use your thumbs to firmly, but carefully push the LCD screen cover out and into your fingers on the other side of the front panel.
다른 2명이 해당 안내서를 완성하였습니다.
