주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
This guide helps you replace the Fluke 77 Series III Multimeter's PCA. The PCA is the main circuit board of the Multimeter and is therefore its most important part.
  1. Be sure any test leads are out and the multimeter is off before opening the device.
    • Be sure any test leads are out and the multimeter is off before opening the device.
    • Turn the multimeter so it is display side down.
    • Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
  2. Use your Phillips #2 Screwdriver to remove the four black 21 mm Phillips #2 screws.
    • Use your Phillips #2 Screwdriver to remove the four black 21 mm Phillips #2 screws.
  3. Turn the Fluke 77 Series III Multimeter back over so that it is display side up. Pry the front panel from the back panel at the seam.
    • Turn the Fluke 77 Series III Multimeter back over so that it is display side up.
    • Pry the front panel from the back panel at the seam.
    • If the front panel does not come off easily, move a plastic opening tool along the seam until the panels separate completely.
  4. When doing this next step, make sure to remove the battery slowly, so you don't damage the wires connecting the battery to the device. Locate the 9V battery in the lower right corner of the device.
    • When doing this next step, make sure to remove the battery slowly, so you don't damage the wires connecting the battery to the device.
    • Locate the 9V battery in the lower right corner of the device.
    • Pull the battery out of its terminal.
  5. Only pull on the metal snaps and battery. Pulling the cords may damage them. Detach the two metal snaps from the battery.
    • Only pull on the metal snaps and battery. Pulling the cords may damage them.
    • Detach the two metal snaps from the battery.
  6. Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
    Nintendo Switch 키트 쇼핑하기
    Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
  7. Replace a fuse only with a fuse identical in type, voltage rating, and current rating as specified by the back panel fuse rating label or the Fluke 77 Series III Service Manual. Inserting the wrong replacement fuse could create a fire hazard. Locate the fuses near the bottom left corner inside the device.
    • Replace a fuse only with a fuse identical in type, voltage rating, and current rating as specified by the back panel fuse rating label or the Fluke 77 Series III Service Manual. Inserting the wrong replacement fuse could create a fire hazard.
    • Locate the fuses near the bottom left corner inside the device.
    • Take note of which fuses belong in which location before removal. They are NOT interchangeable.
    • The .440 Amp fuse is located in the upper left hand fuse holder.
    • The 11 Amp fuse is located in the lower right hand fuse holder.
    • Lift the rounded edge of the fuse with one finger until that side is completely out of its holder.
  8. Grab the lifted edge of the fuse between your thumb and forefinger and pull it the rest of the way out of the device.
    • Grab the lifted edge of the fuse between your thumb and forefinger and pull it the rest of the way out of the device.
    • The fuse in the upper left corner can be tricky to remove. Use a plastic opening tool if needed.
    • Repeat steps 4 and 5 to remove the other fuse if you are replacing both fuses or if you are replacing a different part further on.
  9. Locate the rubber range and hold buttons in the internal assembly. These are found just below the LCD screen on the left hand side. The buttons are attached so they will come out of the multimeter as a single part.
    • Locate the rubber range and hold buttons in the internal assembly. These are found just below the LCD screen on the left hand side.
    • The buttons are attached so they will come out of the multimeter as a single part.
    • Remove the rubber range and hold button part with your thumb and forefinger.
  10. Locate the silver 7 mm screw found underneath the 11A fuse.
    • Locate the silver 7 mm screw found underneath the 11A fuse.
    • Using the Phillips #0 Screwdriver, unscrew and remove the silver 7 mm Phillips #0 screw that attaches the back panel to the internal cover.
  11. Lift the grey internal cover out of the back panel.
    • Lift the grey internal cover out of the back panel.
    • You should now have the grey internal cover that's connected to the PCA circuit board and the plastic back panel in two separate pieces.
  12. Turn the internal assembly over so that the green circuit board (PCA) is visible.
    • Turn the internal assembly over so that the green circuit board (PCA) is visible.
    • Locate the five silver 11 mm Phillips #1 screws on the upper part of the circuit board that hold it to the the grey plastic internal cover.
  13. Use the Phillips #1 Screwdriver to remove the five silver 11 mm Phillips #1 screws attaching the green circuit board to the grey plastic internal cover.
    • Use the Phillips #1 Screwdriver to remove the five silver 11 mm Phillips #1 screws attaching the green circuit board to the grey plastic internal cover.
  14. Do not touch any of the chips on the underside of the circuit board because static electricity on your hands could damage them.
    • Do not touch any of the chips on the underside of the circuit board because static electricity on your hands could damage them.
    • Carefully lift the circuit board up and away from the internal cover.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jessica Bombardier Shaw
회원 가입일: 2014년 01월 29일
1,000 평판
안내서 7개 작성하였습니다
Cal Poly, Team 2-10, Amido Winter 2014 Cal Poly, Team 2-10, Amido Winter 2014 회원
CPSU-AMIDO-W14S2G10
4 회원들
안내서 10개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 31
전체 시간: 3,291
