주요 콘텐츠로 건너뛰기
Flute Head Cork Replacement
필요한 것
  1. Flute Head Cork Replacement, Head Cork: 1 단계, 이미지 1/3 Flute Head Cork Replacement, Head Cork: 1 단계, 이미지 2/3 Flute Head Cork Replacement, Head Cork: 1 단계, 이미지 3/3
    • Unscrew the Flute Crown.
    • Use pliers to grip the protruding screw and pull out the old cork.
  2. Flute Head Cork Replacement: 2 단계, 이미지 1/3 Flute Head Cork Replacement: 2 단계, 이미지 2/3 Flute Head Cork Replacement: 2 단계, 이미지 3/3
    • Use a razor blade to cut the glue around the base of the screw set up.
    • Use a razor blade to cut the glue around the removable washer at the top of the cork.
    • Use a razor blade to make two lengthwise cuts on opposite sides of the cork.
    • Break the cork off of the screw.
  3. Flute Head Cork Replacement: 3 단계, 이미지 1/3 Flute Head Cork Replacement: 3 단계, 이미지 2/3 Flute Head Cork Replacement: 3 단계, 이미지 3/3
    • Use a small paintbrush to brush on a layer of contact cement onto the bottom of the new cork and the bottom of the screw set up.
    • Let contact cement sit for a few minutes and then slide the cork down onto the screw rod glue side first.
  4. Flute Head Cork Replacement: 4 단계, 이미지 1/3 Flute Head Cork Replacement: 4 단계, 이미지 2/3 Flute Head Cork Replacement: 4 단계, 이미지 3/3
    • Use a small paintbrush to paint a layer of polyurethane glue onto the top of the cork.
    • Do not use contact cement for this step because it will bind on contact and the washer needs to be screwed on.
    • Screw the washer onto the screw rod.
    • Wait for all the glues to dry.
  5. Flute Head Cork Replacement: 5 단계, 이미지 1/3 Flute Head Cork Replacement: 5 단계, 이미지 2/3 Flute Head Cork Replacement: 5 단계, 이미지 3/3
    • Drop the new cork and screw set up screw first into the bottom of the head joint. If the cork is the correct diameter you should be able to see it partially through the embouchure hole.
    • Flute head joints have a tapered diameter that is smaller at the top. This will not work if the cork is put into the top of the head joint.
    • Use the flute tuning rod to push the cork into the head joint until the tuning line at the bottom of the rod is in the middle of the embouchure hole.
    • If the cork is difficult to push down, paraffin wax can be rubbed onto the cork to help lubricate it.
  6. Flute Head Cork Replacement: 6 단계, 이미지 1/2 Flute Head Cork Replacement: 6 단계, 이미지 2/2
    • Screw the crown back onto the screw set up and play the instrument to test that the new cork works.
결승점
Zoe Bixler
회원 가입일: 02/17/21
133 평판
안내서 1개 작성함
Texas Tech, Team S3-G25, Cowan Spring 2021 Texas Tech, Team S3-G25, Cowan Spring 2021 회원
TTU-COWAN-S21S3G25
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 27
전체 시간: 1,380
