주요 콘텐츠로 건너뛰기
Fob watch Battery Replacement
필요한 것
  1. Fob watch Battery Replacement, Battery: 1 단계, 이미지 1/2 Fob watch Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the watch from the silicon casing and turn the watch over.
    • Locate the small indent on the edge of the back plate.
  2. Fob watch Battery Replacement: 2 단계, 이미지 1/3 Fob watch Battery Replacement: 2 단계, 이미지 2/3 Fob watch Battery Replacement: 2 단계, 이미지 3/3
    • Wedge the tip of a Jimmy underneath the indent to lift off the back plate.
    • Use a safe tool to avoid accidents.
  3. Fob watch Battery Replacement: 3 단계, 이미지 1/2 Fob watch Battery Replacement: 3 단계, 이미지 2/2
    • Insert a spudger underneath the white plastic that holds the movement in place.
    • Lift the plastic up and remove.
    • Use an ESD safe tool near the battery or other internal components.
  4. Fob watch Battery Replacement: 4 단계, 이미지 1/2 Fob watch Battery Replacement: 4 단계, 이미지 2/2
    • Locate the small circle battery
    • Wedge the tip of the spudger underneath the small circle battery and lift it out.
    • Do not use a knife or other metal tool with a battery or other internal component as this could cause damage.
  5. Fob watch Battery Replacement: 5 단계, 이미지 1/2 Fob watch Battery Replacement: 5 단계, 이미지 2/2
    • Insert the new battery.
결론
To reassemble your watch, follow these instructions in reverse order. Pull out and turn the dial on the side of the watch to adjust the time.
다른 한 분이 해당 안내서를 완성하였습니다.
Lilli Morgan
회원 가입일: 03/05/19
148 평판
안내서 1개 작성함
Massey University, Team S1-G1, Rauch Fall 2019 Massey University, Team S1-G1, Rauch Fall 2019 회원
MUNZ-RAUCH-F19S1G1
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 40
30일 전: 173
전체 시간: 15,014
