이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will assist you to change the battery on a fob watch. These watches are worn on the chest, and are often used by nurses and other healthcare professionals to easily see the time, aid in clinical assessment, and to maintain infection control by avoiding the use of a wristwatch.
The battery in a fob watch can be changed easily.
필요한 것
Remove the watch from the silicon casing and turn the watch over.
Locate the small indent on the edge of the back plate.
To reassemble your watch, follow these instructions in reverse order. Pull out and turn the dial on the side of the watch to adjust the time.
다른 한 분이 해당 안내서를 완성하였습니다.
