주요 콘텐츠로 건너뛰기
Foldable Grocery Cart Wheels Replacement
필요한 것
  1. Foldable Grocery Cart Wheels Replacement, Wheels: 1 단계, 이미지 1/3 Foldable Grocery Cart Wheels Replacement, Wheels: 1 단계, 이미지 2/3 Foldable Grocery Cart Wheels Replacement, Wheels: 1 단계, 이미지 3/3
    • Using a large needle nose plier, take out the stoppers from each side of the axle.
  2. Foldable Grocery Cart Wheels Replacement: 2 단계, 이미지 1/2 Foldable Grocery Cart Wheels Replacement: 2 단계, 이미지 2/2
    • Use the large needle nose pliers to pull out the locking pins from the holes in the axel to detach the axel from the cart's legs.
    • Repeat for both sides.
  3. Foldable Grocery Cart Wheels Replacement: 3 단계, 이미지 1/3 Foldable Grocery Cart Wheels Replacement: 3 단계, 이미지 2/3 Foldable Grocery Cart Wheels Replacement: 3 단계, 이미지 3/3
    • Carefully pull out the axle to detach it from the cart’s legs.
    • The washers and springs may fall out.
  4. Foldable Grocery Cart Wheels Replacement: 4 단계, 이미지 1/3 Foldable Grocery Cart Wheels Replacement: 4 단계, 이미지 2/3 Foldable Grocery Cart Wheels Replacement: 4 단계, 이미지 3/3
    • Slide off the first washer, the spring, and the second washer.
  5. Foldable Grocery Cart Wheels Replacement: 5 단계, 이미지 1/2 Foldable Grocery Cart Wheels Replacement: 5 단계, 이미지 2/2
    • Take out the tattered wheel.
    • Make sure to keep the third washer on the axle.
    • Repeat steps 4 and 5 for the second wheel.
  6. Foldable Grocery Cart Wheels Replacement: 6 단계, 이미지 1/3 Foldable Grocery Cart Wheels Replacement: 6 단계, 이미지 2/3 Foldable Grocery Cart Wheels Replacement: 6 단계, 이미지 3/3
    • Take one of the new wheels and slide it on one side of the axle.
  7. Foldable Grocery Cart Wheels Replacement: 7 단계, 이미지 1/3 Foldable Grocery Cart Wheels Replacement: 7 단계, 이미지 2/3 Foldable Grocery Cart Wheels Replacement: 7 단계, 이미지 3/3
    • Slide on the first washer, the spring, and then the second washer back on the axle.
    • Repeat steps 6 and 7 for the second wheel.
  8. Foldable Grocery Cart Wheels Replacement: 8 단계, 이미지 1/3 Foldable Grocery Cart Wheels Replacement: 8 단계, 이미지 2/3 Foldable Grocery Cart Wheels Replacement: 8 단계, 이미지 3/3
    • Carefully place the front wheel axle with the new wheels in the side holes of the cart’s legs.
  9. Foldable Grocery Cart Wheels Replacement: 9 단계, 이미지 1/3 Foldable Grocery Cart Wheels Replacement: 9 단계, 이미지 2/3 Foldable Grocery Cart Wheels Replacement: 9 단계, 이미지 3/3
    • Insert the locking pins in each hole at both ends of the axle until the pins are halfway in the hole.
    • Using the hammer, tap the pins until they are entirely inside the hole.
  10. Foldable Grocery Cart Wheels Replacement: 10 단계, 이미지 1/3 Foldable Grocery Cart Wheels Replacement: 10 단계, 이미지 2/3 Foldable Grocery Cart Wheels Replacement: 10 단계, 이미지 3/3
    • Lastly, push the stoppers in each hole of the cart's legs.
    • Using the hammer, tap them in place.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Saba Aafreen
회원 가입일: 06/30/21
232 평판
안내서 1개 작성함
York University, Team S2-G1, Melo-Thaiss Summer 2021 York University, Team S2-G1, Melo-Thaiss Summer 2021 회원
YORK-MELO-THAISS-SU21S2G1
1 회원
안내서 3개 작성하였습니다
댓글 한 개
My back wheels need replacing. Can I use a different size because I’m having trouble finding the size I need. If they are a little bigger or smaller will it work. My wheels are non caster type wheels.
MoMac - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 68
30일 전: 300
전체 시간: 9,103
