주요 콘텐츠로 건너뛰기
FoodSaver V4980 Seal Profile Replacement
  1. FoodSaver V4980 Seal Profile Replacement, Seal Profile: 1 단계, 이미지 1/1
    • Open the drawer on the bottom side of the FoodSaver first.
  2. FoodSaver V4980 Seal Profile Replacement: 2 단계, 이미지 1/1
    • Gently pull the sides of the rubber seal profile with a finger and remove it from the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Mackenzie Grossgold
회원 가입일: 04/14/16
940 평판
안내서 6개 작성하였습니다
Cal Poly, Team 34-17, Maness Spring 2016 Cal Poly, Team 34-17, Maness Spring 2016 회원
CPSU-MANESS-S16S34G17
4 회원들
안내서 6개 작성하였습니다
댓글 2개
Does anyone else have difficulty pulling the drip tray out? I’ve released the tabs on the bottom of the unit and tried pulling on the tray. I detect some movement but it won’t come out. If I pull any harder, I’ll probably break it.
Jerry - 답글
Who sells the parts for the Food Saver?
Bruce Carlton - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 13
30일 전: 46
전체 시간: 9,269
