주요 콘텐츠로 건너뛰기
Ford Focus Door Interior dome light assembly Replacement
필요한 것
  1. Ford Focus Door Interior dome light assembly Replacement, interior dome light: 1 단계, 이미지 1/2 Ford Focus Door Interior dome light assembly Replacement, interior dome light: 1 단계, 이미지 2/2
    • Remove the screw cover in the handle housing using a flathead screwdriver.
  2. Ford Focus Door Interior dome light assembly Replacement: 2 단계, 이미지 1/2 Ford Focus Door Interior dome light assembly Replacement: 2 단계, 이미지 2/2
    • Remove the screw that is holding the handle housing with a T20 Torx screwdriver.
  3. Ford Focus Door Interior dome light assembly Replacement: 3 단계, 이미지 1/2 Ford Focus Door Interior dome light assembly Replacement: 3 단계, 이미지 2/2
    • Carefully pull the handle housing off.
    • Do not pull too hard. There are wires attached to the back of the housing.
  4. Ford Focus Door Interior dome light assembly Replacement: 4 단계, 이미지 1/3 Ford Focus Door Interior dome light assembly Replacement: 4 단계, 이미지 2/3 Ford Focus Door Interior dome light assembly Replacement: 4 단계, 이미지 3/3
    • Detach the wires on the handle housing with a flathead screwdriver by pushing upwards on the release slot.
  5. Ford Focus Door Interior dome light assembly Replacement: 5 단계, 이미지 1/2 Ford Focus Door Interior dome light assembly Replacement: 5 단계, 이미지 2/2
    • Remove the cover on the door grip by prying gently with a flathead screwdriver.
  6. Ford Focus Door Interior dome light assembly Replacement: 6 단계, 이미지 1/2 Ford Focus Door Interior dome light assembly Replacement: 6 단계, 이미지 2/2
    • Take off the inside door panel by removing all screws with a T20 Torx screwdriver.
    • There are nine screws in total: two on the front, three on the outer side, two on bottom, and two on the inner side.
  7. Ford Focus Door Interior dome light assembly Replacement: 7 단계, 이미지 1/3 Ford Focus Door Interior dome light assembly Replacement: 7 단계, 이미지 2/3 Ford Focus Door Interior dome light assembly Replacement: 7 단계, 이미지 3/3
    • Pull the insulation back to access the door handle bracket.
    • Use an X-acto knife if needed.
  8. Ford Focus Door Interior dome light assembly Replacement: 8 단계, 이미지 1/3 Ford Focus Door Interior dome light assembly Replacement: 8 단계, 이미지 2/3 Ford Focus Door Interior dome light assembly Replacement: 8 단계, 이미지 3/3
    • Remove the two screws holding the handle bracket with a T20 Torx screwdriver.
  9. Ford Focus Door Interior dome light assembly Replacement: 9 단계, 이미지 1/3 Ford Focus Door Interior dome light assembly Replacement: 9 단계, 이미지 2/3 Ford Focus Door Interior dome light assembly Replacement: 9 단계, 이미지 3/3
    • Remove the outside door handle by prying gently with a flathead screwdriver to loosen, and then slide it back.
  10. Ford Focus Door Interior dome light assembly Replacement: 10 단계, 이미지 1/3 Ford Focus Door Interior dome light assembly Replacement: 10 단계, 이미지 2/3 Ford Focus Door Interior dome light assembly Replacement: 10 단계, 이미지 3/3
    • Detach the door latch rod from the handle bracket by pulling the plastic end out of the metal loop.
  11. Ford Focus Door Interior dome light assembly Replacement: 11 단계, 이미지 1/2 Ford Focus Door Interior dome light assembly Replacement: 11 단계, 이미지 2/2
    • Pull the locking rod free from the handle bracket and remove the broken handle bracket.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Cassidy
회원 가입일: 03/21/16
241 평판
안내서 1개 작성함
Michigan Tech, Team 1-11, Lauer Spring 2016 Michigan Tech, Team 1-11, Lauer Spring 2016 회원
MTU-LAUER-S16S1G11
1 회원
안내서 2개 작성하였습니다
댓글 한 개
Excellent guide. I should have watched the video before disassembly. Actually got part from coastal ford for $40. Same as napa but actual Ford part! And in stock. Thanks Glen
glenthomas784 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 47
전체 시간: 23,215
