소개
We will demonstrate how to remove the radio suppression capacitor in a 2007 Ford Focus and replace it with a new capacitor by using a ratcheting screwdriver and 8mm nut driver attachment.
The radio suppression capacitor acts as a noise barrier as it dampens engine noise in the cabin of the vehicle. However, sometimes the wire in the capacitor corrodes and fails to dampen noise from the engine. Additionally, the wire may come loose, blowing fuses or even the battery.
필요한 것
Pop the hood of the 2007 Ford Focus using the pull lever under the steering wheel.
Secure the hood with the hood prop on the left side of the engine.
Install the new capacitor by following the steps above in reverse order.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 한 개
Do I have to have this part as it keeps arcing on the body or frame of my car and shorten out my ignition fuse. So do I have to have this part because I noticed when I unplugged it my car cranked up and ran because I forgot to plug it back in. How long can I run without it and what damage does it do? Because I know it has to do with the radio interference with within the steering wheel or something like that and I have no radio so I don't know if that matters
