주요 콘텐츠로 건너뛰기
Forerunner 620 Battery and/or Screen Replacement
필요한 것
  1. Forerunner 620 Battery and/or Screen Replacement, Remove LCD: 1 단계, 이미지 2개 중 1개 Forerunner 620 Battery and/or Screen Replacement, Remove LCD: 1 단계, 이미지 2개 중 2개
    • Carefully remove the display of the watch by thoroughly heating the display and gently prying with the help of a suction cup.
  2. Forerunner 620 Battery and/or Screen Replacement, Remove the main board: 2 단계, 이미지 1개 중 1개
    • Remove the screws which secure the main board in place.
  3. Forerunner 620 Battery and/or Screen Replacement, Replace battery: 3 단계, 이미지 3개 중 1개 Forerunner 620 Battery and/or Screen Replacement, Replace battery: 3 단계, 이미지 3개 중 2개 Forerunner 620 Battery and/or Screen Replacement, Replace battery: 3 단계, 이미지 3개 중 3개
    • If the connector for the battery breaks, you can solder the connections directly to the motherboard.
    • If the connector is still intact, you can simply clip the new one into place.
  4. Forerunner 620 Battery and/or Screen Replacement, Replace the LCD: 4 단계, 이미지 1개 중 1개
    • If the LCD is broken, you can replace it by removing the two flat cables which connect it to the main board.
    • The touch screen cable has a lock with a small white lever which should be lifted gently to remove the cable.
  5. Forerunner 620 Battery and/or Screen Replacement, Glue and put it back: 5 단계, 이미지 3개 중 1개 Forerunner 620 Battery and/or Screen Replacement, Glue and put it back: 5 단계, 이미지 3개 중 2개 Forerunner 620 Battery and/or Screen Replacement, Glue and put it back: 5 단계, 이미지 3개 중 3개
    • You can now glue the display back in place using B-7000 adhesive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
phico
회원 가입일: 03/22/21
295 평판
안내서 2개를 작성함
10가이드 댓글
Where did you find the replacement battery?
Clarence Chung - 답글
I bought this model on Amazon : "
CELLONIC® Smartwatch Replacement Battery PD3032, 361-00047-0 Compatible with Garmin Approach S1, Forerunner 110, Forerunner 210, Forerunner 610, Forerunner S1 Replacement Battery 200 mAh Battery Fitness Tracker
Philippe Collignon -
Do you have the dimensions of the original battery?
Clarence Chung - 답글
Is B7000 adhesive necessary?... or will E6000 also work the same?
Thanks in advance.
jjc - 답글
Changed the battery, all good, except that the touch screen is no longer responding to my touch. :<
Clarence Chung - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 53
전체 시간: 3,705
