주요 콘텐츠로 건너뛰기
Fosera Scandle 200 Motherboard Removal
필요한 것
  1. Fosera Scandle 200 Motherboard Removal, Motherboard Removal: 1 단계, 이미지 1/1
    • To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
  2. Fosera Scandle 200 Motherboard Removal: 2 단계, 이미지 1/1
    • Gently separate the two halves of the casing.
  3. Fosera Scandle 200 Motherboard Removal: 3 단계, 이미지 1/1
    • Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
    • Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
  4. Fosera Scandle 200 Motherboard Removal: 4 단계, 이미지 1/1
    • Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
  5. Fosera Scandle 200 Motherboard Removal: 5 단계, 이미지 1/1
    • Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
결승점
Vladislav Ignatov
회원 가입일: 09/23/14
585 평판
안내서 3개 작성하였습니다
USF Tampa, Team 12-5, Blackwell Fall 2014 USF Tampa, Team 12-5, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S12G5
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 271
