주요 콘텐츠로 건너뛰기
Fossil Q Marshal Gen 2 Motherboard Replacement
필요한 것
  1. Fossil Q Marshal Gen 2 Motherboard Replacement, Back Cover: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
    • Remove chain from opposing side of watch body.
  2. Fossil Q Marshal Gen 2 Motherboard Replacement: 2 단계, 이미지 1/1
    • Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
    • There is an actual tool made to remove this back cover, using the right tool may save you from scratching the back of watch with tweezers. The backcover tool can be purchased online, a local jeweler may also be willing to remove it for you.
  3. Fossil Q Marshal Gen 2 Motherboard Replacement: 3 단계, 이미지 1/2 Fossil Q Marshal Gen 2 Motherboard Replacement: 3 단계, 이미지 2/2
    • Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
    • Utilize a spudger to pull the orange connector off of the motherboard.
  4. Fossil Q Marshal Gen 2 Motherboard Replacement: 4 단계, 이미지 1/1
    • Utilize tweezers to pull the white battery connector from the motherboard.
  5. Fossil Q Marshal Gen 2 Motherboard Replacement: 5 단계, 이미지 1/3 Fossil Q Marshal Gen 2 Motherboard Replacement: 5 단계, 이미지 2/3 Fossil Q Marshal Gen 2 Motherboard Replacement: 5 단계, 이미지 3/3
    • The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
    • Taking the flat end of the spudger, pry it up.
  6. Fossil Q Marshal Gen 2 Motherboard Replacement, Battery: 6 단계, 이미지 1/1
    • The battery is secured to the back of the motherboard utilizing a sticky pad. Gently separate the battery from the board while making sure not to put too much stress on the board. This is best done at the location shown.
  7. Fossil Q Marshal Gen 2 Motherboard Replacement: 7 단계, 이미지 1/2 Fossil Q Marshal Gen 2 Motherboard Replacement: 7 단계, 이미지 2/2
    • Remove battery from plastic housing.
    • Slip wires through large slot in plastic housing to completely remove.
  8. Fossil Q Marshal Gen 2 Motherboard Replacement, Motherboard: 8 단계, 이미지 1/1
    • Using your finger remove the metal hooks from the black electronic housing.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Matthew Tucker
회원 가입일: 11/07/17
580 평판
안내서 3개 작성하였습니다
IUPUI, Team S2-G5, Harley Fall 2017 IUPUI, Team S2-G5, Harley Fall 2017 회원
IUPUI-HARLEY-F17S2G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 2,882
