주요 콘텐츠로 건너뛰기
Fossil Speedway Watch TI-5061 Battery Replacement
필요한 것
  1. Fossil Speedway Watch TI-5061 Battery Replacement, Clasp: 1 단계, 이미지 1/3 Fossil Speedway Watch TI-5061 Battery Replacement, Clasp: 1 단계, 이미지 2/3 Fossil Speedway Watch TI-5061 Battery Replacement, Clasp: 1 단계, 이미지 3/3
    • Keep clasp in open position.
    • Push one of the spring-loaded pins out of the hole with a Push-pin.
    • Wiggle watch band and clasp till free from each other.
  2. Fossil Speedway Watch TI-5061 Battery Replacement, Back: 2 단계, 이미지 1/1
    • Fit the blades of a pair of scissors into the grooves of the screw back.
    • Twist the screw back counter clockwise with the scissors.
    • Once the back is loose enough, you can use your fingers to twist it off.
  3. Fossil Speedway Watch TI-5061 Battery Replacement, Battery: 3 단계, 이미지 1/2 Fossil Speedway Watch TI-5061 Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Place the tweezers around the battery.
    • Firmly grip the battery with the tweezers.
    • Pull the battery out and replace it with a new 371 Renata watch battery.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Caleb
회원 가입일: 04/21/15
370 평판
안내서 1개 작성함
Cal Poly, Team 14-10, Amido Spring 2015 Cal Poly, Team 14-10, Amido Spring 2015 회원
CPSU-AMIDO-S15S14G10
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 23
30일 전: 77
전체 시간: 4,891
