소개
Sometimes, fixing a watch is as simple as replacing a watch battery. Instead of taking the watch to a professional, replacing the battery can be done quickly and easily in the comfort of your own home. Here we will teach you to remove the battery and put a new one in with a few simple steps.
필요한 것
Keep clasp in open position.
Push one of the spring-loaded pins out of the hole with a Push-pin.
Wiggle watch band and clasp till free from each other.
Place the tweezers around the battery.
Firmly grip the battery with the tweezers.
Pull the battery out and replace it with a new 371 Renata watch battery.
다른 5명이 해당 안내서를 완성하였습니다.
