소개
If the back of the watch is damaged or seems faulty in some way (no longer water resistant, rusted, etc), you can follow these simple steps to replace it.
Be aware that using scissors may be a dangerous way to remove the back of the watch. It could scratch the back of the watch or it could give you a serious cut. Be careful when using scissors to open the back of the watch. Alternatively, you could click here to view a guide with the proper tools. Another thing to be aware of is that the parts in your watch are very small and fragile. Be wary not to break or lose any parts.
필요한 것
Keep clasp in open position.
Push one of the spring-loaded pins out of the hole with a Push-pin.
Wiggle watch band and clasp till free from each other.
다른 2명이 해당 안내서를 완성하였습니다.
