주요 콘텐츠로 건너뛰기
Fossil Speedway Watch TI-5061 Time Setting Dial Replacement
필요한 것
  1. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Clasp: 1 단계, 이미지 1/3 Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Clasp: 1 단계, 이미지 2/3 Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Clasp: 1 단계, 이미지 3/3
    • Keep clasp in open position.
    • Push one of the spring-loaded pins out of the hole with a Push-pin.
    • Wiggle watch band and clasp till free from each other.
  2. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Back: 2 단계, 이미지 1/1
    • Fit the blades of a pair of scissors into the grooves of the screw back.
    • Twist the screw back counter clockwise with the scissors.
    • Once the back is loose enough, you can use your fingers to twist it off.
  3. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Time Setting Dial: 3 단계, 이미지 1/2 Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Time Setting Dial: 3 단계, 이미지 2/2
    • Press the release button for the Time Setting Dial using a thin pin.
  4. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement: 4 단계, 이미지 1/2 Fossil Speedway Watch TI-5061 Time Setting Dial Replacement: 4 단계, 이미지 2/2
    • Pull the dial out gently with fingers.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Julia List
회원 가입일: 04/21/15
5,610 평판
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 28
전체 시간: 1,164
