주요 콘텐츠로 건너뛰기
Fossil Speedway Watch TI-5061 Watchband Link Replacement
필요한 것
  1. Fossil Speedway Watch TI-5061 Watchband Link Replacement, Band Link: 1 단계, 이미지 1/1
    • Locate the link on the band with arrows pointing in opposite directions.
    • Place push pin into the hole on one side of the link.
  2. Fossil Speedway Watch TI-5061 Watchband Link Replacement: 2 단계, 이미지 1/1
    • Hit the push pin with the blunt object (we used scissors) until the small metal rod sticks out from the link.
    • Pull the rod out using your fingers.
    • Repeat on the other side to remove the entire link.
  3. Fossil Speedway Watch TI-5061 Watchband Link Replacement: 3 단계, 이미지 1/2 Fossil Speedway Watch TI-5061 Watchband Link Replacement: 3 단계, 이미지 2/2
    • To replace the link, insert the open end of one of the connected links into the open end of the new link.
    • Place the rod into the aligning holes and use the blunt object to hammer the rod into the link.
    • Repeat on the other side of the link to remove it completely.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Zachary Price
회원 가입일: 04/28/15
588 평판
안내서 3개 작성하였습니다
Cal Poly, Team 14-10, Amido Spring 2015 Cal Poly, Team 14-10, Amido Spring 2015 회원
CPSU-AMIDO-S15S14G10
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
Looking for 3 extra watch band links for a fossil big tic model jr8622 18mm width could you tell me please how much this will cost please with delivery as well to croydon in Surrey
Kind regards colin
Colin Evans - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 35
전체 시간: 1,347
