주요 콘텐츠로 건너뛰기
Framework Desktop Antennas Replacement
필요한 것
  1. Framework Desktop Antennas Replacement, Power down your Desktop: 1 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Power down your Desktop: 1 단계, 이미지 2개 중 2개
    • Before you begin repairs, shut down your Desktop from the operating system and unplug it.
    • Wait one minute before continuing to allow your Desktop to fully power down.
  2. Framework Desktop Antennas Replacement, Remove the Handle: 2 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Remove the Handle: 2 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Remove the Handle: 2 단계, 이미지 3개 중 3개
    • If you installed the Handle on your Desktop, follow this step. Otherwise, skip it.
    • Rotate the Handle's screw threads counterclockwise on both sides until it comes free.
    • Remove the Handle.
  3. Framework Desktop Antennas Replacement, Remove the Top Panel screws: 3 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Remove the Top Panel screws: 3 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Remove the Top Panel screws: 3 단계, 이미지 3개 중 3개
    • Use your finger to lift up the two D-rings on the Top Panel screws.
  4. Framework Desktop Antennas Replacement: 4 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement: 4 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement: 4 단계, 이미지 3개 중 3개
    • Use your fingers to twist the screw counter-clockwise and loosen it.
    • Remove the Top Panel screw.
  5. Framework Desktop Antennas Replacement: 5 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement: 5 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement: 5 단계, 이미지 3개 중 3개
    • Repeat the same procedure for the other Top Panel screw.
  6. Framework Desktop Antennas Replacement, Remove the Top Panel: 6 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Remove the Top Panel: 6 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Remove the Top Panel: 6 단계, 이미지 3개 중 3개
    • Slide the Top Panel towards the rear of the computer to release the clips securing it to the chassis.
    • If you're having a hard time gripping the Top Panel, use the screw holes to get a better handhold.
    • Lift the Top Panel off the chassis and remove it.
  7. Framework Desktop Antennas Replacement, Remove the Left Panel: 7 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Remove the Left Panel: 7 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Remove the Left Panel: 7 단계, 이미지 3개 중 3개
    • Use your fingers to grip the top of the Left Panel and slide it upward to release its clips.
    • Remove the Left Panel.
  8. Framework Desktop Antennas Replacement, Lay down the Desktop: 8 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Lay down the Desktop: 8 단계, 이미지 2개 중 2개
    • Lay down the Desktop on its side so the fan is facing upward.
  9. Framework Desktop Antennas Replacement, Disconnect the fan: 9 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Disconnect the fan: 9 단계, 이미지 2개 중 2개
    • Use your fingers to lift the APU fan cable connector off its four‑pronged socket on the Mainboard.
  10. Framework Desktop Antennas Replacement: 10 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement: 10 단계, 이미지 2개 중 2개
    • If you aren't using an RGB fan, then skip this step.
    • Use your fingers to lift the fan RGB cable connector off its three‑pronged socket on the Mainboard.
  11. Framework Desktop Antennas Replacement, Remove the CPU fan screws: 11 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Remove the CPU fan screws: 11 단계, 이미지 2개 중 2개
    • Use your Framework Desktop Screwdriver to remove the four 27.3 mm‑long Phillips screws securing the CPU fan and fan duct.
  12. Framework Desktop Antennas Replacement, Remove the fan duct: 12 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Remove the fan duct: 12 단계, 이미지 2개 중 2개
    • Lift the fan duct off the fan and remove it.
  13. Framework Desktop Antennas Replacement, Remove the fan: 13 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Remove the fan: 13 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Remove the fan: 13 단계, 이미지 3개 중 3개
    • Lift the fan out of the chassis, making sure the cables thread through the side of the heatsink.
  14. Framework Desktop Antennas Replacement, Disconnect the top Expansion Card cable: 14 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Disconnect the top Expansion Card cable: 14 단계, 이미지 2개 중 2개
    • Pull the top Expansion Card connector straight out of its socket in the Mainboard to disconnect it.
  15. Framework Desktop Antennas Replacement, Disconnect the main power cable: 15 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Disconnect the main power cable: 15 단계, 이미지 2개 중 2개
    • While squeezing the clip on the main power cable, pull it straight up and out of its socket to disconnect it.
  16. Framework Desktop Antennas Replacement, Disconnect the CPU power cable: 16 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Disconnect the CPU power cable: 16 단계, 이미지 2개 중 2개
    • While squeezing the clip on the CPU power cable, pull it straight up and out of its socket to disconnect it.
  17. Framework Desktop Antennas Replacement, Disconnect the bottom Expansion Card cable: 17 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Disconnect the bottom Expansion Card cable: 17 단계, 이미지 2개 중 2개
    • Pull the bottom Expansion Card connector straight out of its socket in the Mainboard to disconnect it.
  18. Framework Desktop Antennas Replacement, Reposition the Desktop: 18 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Reposition the Desktop: 18 단계, 이미지 2개 중 2개
    • Lift the Desktop so it stands upright on your work surface.
  19. Framework Desktop Antennas Replacement, Remove the Right Panel: 19 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Remove the Right Panel: 19 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Remove the Right Panel: 19 단계, 이미지 3개 중 3개
    • Use your fingers to grip the top of the Right Panel and slide it upward to release its clips.
    • Remove the Right Panel.
  20. Framework Desktop Antennas Replacement, Remove the top plate screws: 20 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Remove the top plate screws: 20 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Remove the top plate screws: 20 단계, 이미지 3개 중 3개
    • While holding the Desktop steady, use your Framework Desktop Screwdriver to remove the eight 4.0 mm‑long Phillips screws securing the top plate.
  21. Framework Desktop Antennas Replacement, Remove the top plate: 21 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Remove the top plate: 21 단계, 이미지 2개 중 2개
    • Lift the top plate off the Desktop and remove it.
  22. Framework Desktop Antennas Replacement, Reposition the Desktop: 22 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Reposition the Desktop: 22 단계, 이미지 2개 중 2개
    • Lay the left side of the Desktop on your work surface so the underside of the Mainboard is facing upward.
  23. Framework Desktop Antennas Replacement, Remove the Wi-Fi Module screw: 23 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Remove the Wi-Fi Module screw: 23 단계, 이미지 2개 중 2개
    • Use your Framework Desktop Screwdriver to remove the 7.0 mm‑long Phillips screw securing the Wi-Fi module.
  24. Framework Desktop Antennas Replacement, Remove the Wi-Fi module cover: 24 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Remove the Wi-Fi module cover: 24 단계, 이미지 2개 중 2개
    • Use your fingers to slide the Wi-Fi module cover straight off the bottom of the module.
    • Remove the cover.
  25. Framework Desktop Antennas Replacement, Disconnect the Wi-Fi module: 25 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Disconnect the Wi-Fi module: 25 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Disconnect the Wi-Fi module: 25 단계, 이미지 3개 중 3개
    • The Wi-Fi module has two delicate coaxial cable connectors. Follow this step carefully to avoid damaging them.
    • Press and hold the Wi-Fi module down with your fingers.
    • Use your fingers to grip the white antenna cable, as close to the metal head as possible.
    • If you have angled tweezers, slide one arm of a pair of tweezers under the antenna connector, as close to the metal head as possible.
    • Gently lift the connector straight up to disconnect the white antenna cable.
    • Repeat the procedure with the black antenna cable.
  26. Framework Desktop Antennas Replacement, Remove the Wi-Fi module: 26 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Remove the Wi-Fi module: 26 단계, 이미지 2개 중 2개
    • Grip the Wi-Fi module by its edges and pull it straight out of its socket.
    • Remove the Wi-Fi module.
  27. Framework Desktop Antennas Replacement, Reposition the Desktop: 27 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Reposition the Desktop: 27 단계, 이미지 2개 중 2개
    • Rotate the Desktop onto its right side so the Mainboard is facing upward.
  28. Framework Desktop Antennas Replacement, Disconnect the power button: 28 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Disconnect the power button: 28 단계, 이미지 2개 중 2개
    • Use your fingers to lift the power button cable connector off its nine‑pronged socket on the Mainboard.
  29. Framework Desktop Antennas Replacement, Remove the Mainboard screws: 29 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Remove the Mainboard screws: 29 단계, 이미지 2개 중 2개
    • Use your Framework Desktop Screwdriver to remove the four 8.2 mm‑long Phillips screws securing the Mainboard.
  30. Framework Desktop Antennas Replacement, Remove the Mainboard: 30 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Remove the Mainboard: 30 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Remove the Mainboard: 30 단계, 이미지 3개 중 3개
    • Grab the Mainboard by its heatsink and pull it towards the front of the Desktop to slide it out of the rear port cutout.
    • Slide the Mainboard towards the top of the Desktop to remove it from the chassis.
  31. Framework Desktop Antennas Replacement, Reroute the power button cable: 31 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Reroute the power button cable: 31 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Reroute the power button cable: 31 단계, 이미지 3개 중 3개
    • Pull the power button cable out of its rubber clips on the chassis.
  32. Framework Desktop Antennas Replacement, Reroute the antenna cables: 32 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Reroute the antenna cables: 32 단계, 이미지 2개 중 2개
    • Push the antenna cables out of the metal hook in the chassis.
  33. Framework Desktop Antennas Replacement: 33 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement: 33 단계, 이미지 2개 중 2개
    • Pull the black antenna cable out of the plastic clip in the chassis.
  34. Framework Desktop Antennas Replacement, Peel off the copper film: 34 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Peel off the copper film: 34 단계, 이미지 2개 중 2개
    • Use your fingers to peel the left antenna's copper film off the chassis.
  35. Framework Desktop Antennas Replacement, Remove the left antenna screws: 35 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Remove the left antenna screws: 35 단계, 이미지 2개 중 2개
    • Use your Framework Desktop Screwdriver to remove the two 4.0 mm‑long Phillips screws securing the left antenna.
  36. Framework Desktop Antennas Replacement, Remove the left antenna: 36 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Remove the left antenna: 36 단계, 이미지 2개 중 2개
    • Lift the left antenna out of the chassis and remove it.
  37. Framework Desktop Antennas Replacement, Peel off the copper film: 37 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Peel off the copper film: 37 단계, 이미지 2개 중 2개
    • Use your fingers to peel the right antenna's copper film off the chassis.
  38. Framework Desktop Antennas Replacement, Remove the right antenna screws: 38 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Remove the right antenna screws: 38 단계, 이미지 2개 중 2개
    • Use your Framework Desktop Screwdriver to remove the two 4.0 mm‑long Phillips screws securing the right antenna.
  39. Framework Desktop Antennas Replacement, Remove the right antenna: 39 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Remove the right antenna: 39 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Remove the right antenna: 39 단계, 이미지 3개 중 3개
    • Lift the right antenna out of the chassis, making sure to thread the cable through the slot.
    • Remove the antenna.
  40. Framework Desktop Antennas Replacement, Disassembly complete: 40 단계, 이미지 1개 중 1개
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Desktop.
  41. Framework Desktop Antennas Replacement, Place the right antenna: 41 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Place the right antenna: 41 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Place the right antenna: 41 단계, 이미지 3개 중 3개
    • The replacement antennas look similar. The right antenna has a short, black antenna cable.
    • Place the replacement right antenna into its slot on the chassis, making sure to thread the cable through the slot.
  42. Framework Desktop Antennas Replacement, Install the right antenna screws: 42 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Install the right antenna screws: 42 단계, 이미지 2개 중 2개
    • Use your Framework Desktop Screwdriver to install the two 4.0 mm‑long Phillips screws securing the right antenna.
  43. Framework Desktop Antennas Replacement, Remove the adhesive liner: 43 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Remove the adhesive liner: 43 단계, 이미지 2개 중 2개
    • Remove the liner from the back of your replacement right antenna.
  44. Framework Desktop Antennas Replacement, Adhere the right antenna: 44 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Adhere the right antenna: 44 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Adhere the right antenna: 44 단계, 이미지 3개 중 3개
    • Press the right antenna's copper film onto the chassis and adhere it.
  45. Framework Desktop Antennas Replacement, Place the left antenna: 45 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Place the left antenna: 45 단계, 이미지 2개 중 2개
    • The left antenna has a long, black antenna cable with a white tip.
    • Place the replacement left antenna into its slot on the chassis.
  46. Framework Desktop Antennas Replacement, Install the left antenna screws: 46 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Install the left antenna screws: 46 단계, 이미지 2개 중 2개
    • Use your Framework Desktop Screwdriver to install the two 4.0 mm‑long Phillips screws securing the left antenna.
  47. Framework Desktop Antennas Replacement, Remove the adhesive liner: 47 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Remove the adhesive liner: 47 단계, 이미지 2개 중 2개
    • Remove the liner from the back of your replacement left antenna.
  48. Framework Desktop Antennas Replacement, Adhere the left antenna: 48 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Adhere the left antenna: 48 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Adhere the left antenna: 48 단계, 이미지 3개 중 3개
    • Press the left antenna's copper film onto the chassis and adhere it.
  49. Framework Desktop Antennas Replacement, Reroute the antenna cables: 49 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Reroute the antenna cables: 49 단계, 이미지 2개 중 2개
    • Press the black antenna cable into the plastic clip in the chassis.
  50. Framework Desktop Antennas Replacement: 50 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement: 50 단계, 이미지 2개 중 2개
    • Pull the antenna cables into their metal hook in the chassis.
  51. Framework Desktop Antennas Replacement, Reroute the power button cable: 51 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Reroute the power button cable: 51 단계, 이미지 2개 중 2개
    • Push the power button cable into its rubber clips on the chassis.
  52. Framework Desktop Antennas Replacement, Place the Mainboard: 52 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Place the Mainboard: 52 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Place the Mainboard: 52 단계, 이미지 3개 중 3개
    • Grab the Mainboard by its heatsink and slide it into the chassis.
    • Align the rear ports with its cutout and the screw posts with the screw holes on the Mainboard.
    • You'll feel the Mainboard rest onto the screw posts when it's aligned properly.
    • Make sure no cables are trapped underneath the Mainboard before continuing.
  53. Framework Desktop Antennas Replacement, Install the Mainboard screws: 53 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Install the Mainboard screws: 53 단계, 이미지 2개 중 2개
    • Use your Framework Desktop Screwdriver to install the four 8.2 mm‑long Phillips screws securing the Mainboard.
  54. Framework Desktop Antennas Replacement, Connect the power button: 54 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Connect the power button: 54 단계, 이미지 2개 중 2개
    • Slide the power button cable over the nine-pronged connector on the Mainboard.
  55. Framework Desktop Antennas Replacement, Reposition the Desktop: 55 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Reposition the Desktop: 55 단계, 이미지 2개 중 2개
    • Rotate the Desktop onto its left side so the underside of the Mainboard is facing upward.
  56. Framework Desktop Antennas Replacement, Install the Wi-Fi module: 56 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Install the Wi-Fi module: 56 단계, 이미지 2개 중 2개
    • Hold the Wi-Fi module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
    • Align the Wi-Fi module's gold contacts and notch with the socket on the Mainboard.
    • Insert the Wi-Fi module into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
    • The Wi-Fi module fits into the socket in one orientation. If it doesn't fit, try flipping the module.
  57. Framework Desktop Antennas Replacement, Connect the Wi-Fi Module: 57 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Connect the Wi-Fi Module: 57 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Connect the Wi-Fi Module: 57 단계, 이미지 3개 중 3개
    • Hold the Wi-Fi module down with your fingers.
    • Position the black antenna cable connector over the left Wi-Fi module's coaxial socket.
    • Tweezers can help position the connector.
    • Use your finger to press the connector into place. You should feel a faint click, and the cable will stay attached to the socket by itself.
    • These connectors are very delicate! If the connector doesn't feel like it's clicking in place, reposition the connector and try again.
    • Repeat the procedure with the white antenna cable.
  58. Framework Desktop Antennas Replacement: 58 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement: 58 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement: 58 단계, 이미지 3개 중 3개
    • Hook the Wi-Fi bracket over the corner of the Wi-Fi module opposite the antenna cables.
    • Rotate the bracket over the Wi-Fi module, making sure the screw hole isn't being obstructed by the antenna cables.
  59. Framework Desktop Antennas Replacement, Install the Wi-Fi module screw: 59 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Install the Wi-Fi module screw: 59 단계, 이미지 2개 중 2개
    • Use your Framework Desktop Screwdriver to install the 7.0 mm‑long Phillips screw securing the Wi-Fi module.
  60. Framework Desktop Antennas Replacement, Reposition the Desktop: 60 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Reposition the Desktop: 60 단계, 이미지 2개 중 2개
    • Rotate the Desktop so it sits upright on your work surface.
  61. Framework Desktop Antennas Replacement, Place the top plate: 61 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Place the top plate: 61 단계, 이미지 2개 중 2개
    • Place the top plate on top of the Desktop, making sure it slots into the chassis so the orange circles are visible.
  62. Framework Desktop Antennas Replacement: 62 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement: 62 단계, 이미지 2개 중 2개
    • Make sure the matching screw hole on the top plate labeled "5/8" is slotted on the inside of the Chassis so that the orange circle is visible.
  63. Framework Desktop Antennas Replacement, Install the top plate screws: 63 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Install the top plate screws: 63 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Install the top plate screws: 63 단계, 이미지 3개 중 3개
    • While holding the Desktop steady, use your Framework Desktop Screwdriver to install the eight 4.0 mm‑long Phillips screws securing the top plate.
  64. Framework Desktop Antennas Replacement, Install the Right Panel: 64 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Install the Right Panel: 64 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Install the Right Panel: 64 단계, 이미지 3개 중 3개
    • Slide the Right Panel onto the right edge of the chassis, from top to bottom, and press it flat to ensure its clips are slotted into place.
    • There should be a small gap between the bottom of the Right Panel and the silver base.
    • Push the Right Panel towards the base of the computer to engage the clips.
  65. Framework Desktop Antennas Replacement, Reposition the Mainboard: 65 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Reposition the Mainboard: 65 단계, 이미지 2개 중 2개
    • Lay the right side of the Desktop on your work surface so the Mainboard is facing upward.
  66. Framework Desktop Antennas Replacement, Connect the bottom Expansion Card cable: 66 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Connect the bottom Expansion Card cable: 66 단계, 이미지 2개 중 2개
    • Slide the bottom Expansion Card cable into its socket on the Mainboard.
  67. Framework Desktop Antennas Replacement, Connect the CPU power cable: 67 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Connect the CPU power cable: 67 단계, 이미지 2개 중 2개
    • Orient the CPU power supply cable so its clip is facing the heatsink.
    • Slide the cable into its socket on the Mainboard until you feel it click into place.
  68. Framework Desktop Antennas Replacement, Connect the main power cable: 68 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Connect the main power cable: 68 단계, 이미지 2개 중 2개
    • Orient the main power supply cable so its clip is facing away from the heatsink.
  69. Framework Desktop Antennas Replacement, Connect the top Expansion Card cable: 69 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Connect the top Expansion Card cable: 69 단계, 이미지 2개 중 2개
    • Slide the top Expansion Card cable into its socket on the Mainboard.
  70. Framework Desktop Antennas Replacement, Insert the fan: 70 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Insert the fan: 70 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Insert the fan: 70 단계, 이미지 3개 중 3개
    • Orient the fan so its label is facing downward and the cable(s) is pointing towards the top of the computer.
    • If your fan has an arrow indicating airflow direction, make sure it's pointed towards the heatsink.
    • If you're using a different fan, orient it such that the fan is blowing towards the heatsink, not away.
    • Lay the fan on top of the heatsink, making sure the cables are routed so they poke out of the hole on the top of the computer.
  71. Framework Desktop Antennas Replacement: 71 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement: 71 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement: 71 단계, 이미지 3개 중 3개
    • If the cables aren't routed properly, lift the fan up slightly and use your fingers to reposition the cables over the side of the heatsink.
    • If you're installing an RGB fan, make sure the "male" end of the RGB cable is covered and set aside in the corner of the chassis.
  72. Framework Desktop Antennas Replacement, Insert the fan duct: 72 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Insert the fan duct: 72 단계, 이미지 2개 중 2개
    • Lay the fan duct on top of the fan with the lip facing upward.
    • Align the screw holes on the fan duct with the ones on the fan.
  73. Framework Desktop Antennas Replacement, Install the fan screws: 73 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Install the fan screws: 73 단계, 이미지 2개 중 2개
    • Use your Framework Desktop Screwdriver to install the four 27.3 mm‑long screws securing the fan and fan duct.
  74. Framework Desktop Antennas Replacement, Connect the fan: 74 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Connect the fan: 74 단계, 이미지 2개 중 2개
    • Orient the main fan cable so its two vertical lines are facing you.
    • Slide the main fan cable over the four-pronged connector labeled "APU Fan," making sure the orange label slots between the vertical lines.
  75. Framework Desktop Antennas Replacement, Connect the RGB cable: 75 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Connect the RGB cable: 75 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Connect the RGB cable: 75 단계, 이미지 3개 중 3개
    • Orient the RGB cable so the arrow is on the right side of the connector.
    • Use your fingers to slide the RGB cable over the three pronged connector located to the right of the "APU Fan" connector.
  76. Framework Desktop Antennas Replacement, Loosen the heat spreader screw: 76 단계, 이미지 1개 중 1개
    • Use your Framework Desktop Screwdriver to loosen the captive T5 Torx screw securing the SSD.
  77. Framework Desktop Antennas Replacement, Install the SSD: 77 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Install the SSD: 77 단계, 이미지 2개 중 2개
    • Hold the SSD by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
    • While holding the heat spreader upright, align the SSD's gold contacts with its socket.
    • Insert the SSD into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
    • The SSD fits into the socket in one orientation. If it doesn't feel like it fits, try flipping the module.
  78. Framework Desktop Antennas Replacement, Install the SSD screw: 78 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Install the SSD screw: 78 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Install the SSD screw: 78 단계, 이미지 3개 중 3개
    • Insert your Framework Desktop Screwdriver into the captive screw on the primary storage heat spreader and press it flat to the Mainboard.
    • Tighten the screw securing the SSD.
  79. Framework Desktop Antennas Replacement, Install the Left Panel: 79 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Install the Left Panel: 79 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Install the Left Panel: 79 단계, 이미지 3개 중 3개
    • Slide the Left Panel onto the left edge of the chassis and press it flat to ensure its clips are slotted into place.
    • There should be a small gap between the bottom of the Left Panel and the silver base.
    • Push the Left Panel towards the base of the computer to close the gap and engage the clips.
  80. Framework Desktop Antennas Replacement, Install the Top Panel: 80 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Install the Top Panel: 80 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Install the Top Panel: 80 단계, 이미지 3개 중 3개
    • Orient the Top Panel so its arrow is pointing towards the rear of the computer.
    • While holding the Top Panel at a slight downward angle, slide it across the top of the chassis (from rear to front) until you feel its clips catch.
    • There should be a small gap between the Top Panel and the front of the Desktop.
    • Lay the Top Panel flat on the chassis to align the remaining clips.
  81. Framework Desktop Antennas Replacement: 81 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement: 81 단계, 이미지 2개 중 2개
    • While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips.
  82. Framework Desktop Antennas Replacement, Install the Handle: 82 단계, 이미지 2개 중 1개 Framework Desktop Antennas Replacement, Install the Handle: 82 단계, 이미지 2개 중 2개
    • If you're installing the Handle on your Desktop, follow this step. Otherwise, skip it.
    • Place the Handle over the Top Panel screw holes.
    • While holding the Handle in place, twist the screw threads on both sides clockwise until they're snug on the Top Panel.
  83. Framework Desktop Antennas Replacement, Install the top panel screws: 83 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement, Install the top panel screws: 83 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement, Install the top panel screws: 83 단계, 이미지 3개 중 3개
    • Insert the top panel screw into its hole and twist clockwise until it feels snug.
  84. Framework Desktop Antennas Replacement: 84 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement: 84 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement: 84 단계, 이미지 3개 중 3개
    • Repeat the same procedure for the other top panel screw.
  85. Framework Desktop Antennas Replacement: 85 단계, 이미지 3개 중 1개 Framework Desktop Antennas Replacement: 85 단계, 이미지 3개 중 2개 Framework Desktop Antennas Replacement: 85 단계, 이미지 3개 중 3개
    • Use your finger to close the two D-rings on the top panel screws.
결론
You finished fixing your Framework Desktop!
If you need help, contact Framework support.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
213,465 평판
안내서 1,040개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 18
지난 30일: 64
전체 시간: 71
