주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Framework Desktop Fastener Kit
필요한 것
  1. Framework Desktop Fastener Kit, Fastener information: 1 단계, 이미지 2개 중 1개 Framework Desktop Fastener Kit, Fastener information: 1 단계, 이미지 2개 중 2개
    • The Fastener Kit contains the following:
    • Four screws labeled "6.0 mm fastener with a 7.3 mm diameter 2.3 mm thick"
    • Two large screws labeled "M6 ring screws"
    • Four screws labeled "4.0 mm fastener with a 5.5 mm diameter 2.0 mm thick"
    • Eight screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick"
    • Four long screws labeled "26.5 mm fastener with a 7.0 mm diameter 2.0 mm thick"
    • Your Framework Desktop comes with a spare screw of each size attached to the bottom of the top plate. You can use the Fastener Kit to replenish any screws you used there.
    • Not included in the Fastener Kit is a silver 4.5 mm‑long T5 Torx screw that secures the SSD covers, I/O shield, and USB‑C brackets.
    댓글 쓰기
  2. Framework Desktop Fastener Kit, Top Panel screws: 2 단계, 이미지 3개 중 1개 Framework Desktop Fastener Kit, Top Panel screws: 2 단계, 이미지 3개 중 2개 Framework Desktop Fastener Kit, Top Panel screws: 2 단계, 이미지 3개 중 3개
    • The two screws labeled "M6 ring screws" secure the Top Panel.
    댓글 쓰기
  3. Framework Desktop Fastener Kit, Fan screws: 3 단계, 이미지 2개 중 1개 Framework Desktop Fastener Kit, Fan screws: 3 단계, 이미지 2개 중 2개
    • The long screws labeled "26.5 mm fastener with a 7.0 mm diameter 2.0 mm thick" secure the Fan.
    댓글 쓰기
  4. Framework Desktop Fastener Kit, Mainboard screws: 4 단계, 이미지 2개 중 1개 Framework Desktop Fastener Kit, Mainboard screws: 4 단계, 이미지 2개 중 2개
    • The screws labeled "6.0 mm fastener with a 7.3 mm diameter 2.3 mm thick" secure the Mainboard.
    댓글 쓰기
  5. Framework Desktop Fastener Kit, Power supply screws: 5 단계, 이미지 2개 중 1개 Framework Desktop Fastener Kit, Power supply screws: 5 단계, 이미지 2개 중 2개
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 2.0 mm thick" secure the power supply.
    댓글 쓰기
  6. Framework Desktop Fastener Kit, Top plate screws: 6 단계, 이미지 3개 중 1개 Framework Desktop Fastener Kit, Top plate screws: 6 단계, 이미지 3개 중 2개 Framework Desktop Fastener Kit, Top plate screws: 6 단계, 이미지 3개 중 3개
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the top plate.
    댓글 쓰기
  7. Framework Desktop Fastener Kit, Rear plate screws: 7 단계, 이미지 3개 중 1개 Framework Desktop Fastener Kit, Rear plate screws: 7 단계, 이미지 3개 중 2개 Framework Desktop Fastener Kit, Rear plate screws: 7 단계, 이미지 3개 중 3개
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the rear plate.
    댓글 쓰기
  8. Framework Desktop Fastener Kit, Side power supply screw: 8 단계, 이미지 2개 중 1개 Framework Desktop Fastener Kit, Side power supply screw: 8 단계, 이미지 2개 중 2개
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the side of the power supply.
    댓글 쓰기
  9. Framework Desktop Fastener Kit, Power duct screws: 9 단계, 이미지 3개 중 1개 Framework Desktop Fastener Kit, Power duct screws: 9 단계, 이미지 3개 중 2개 Framework Desktop Fastener Kit, Power duct screws: 9 단계, 이미지 3개 중 3개
    댓글 쓰기
결론
If you need help, contact Framework support.
취소: 해당 안내서를 완성하지 않았습니다.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
239,177 평판
안내서 1,171개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 28
전체 시간: 246
