주요 콘텐츠로 건너뛰기
Framework Laptop 12 Battery Replacement
필요한 것
  1. Framework Laptop 12 Battery Replacement, Power down your laptop: 1 단계, 이미지 3개 중 1개 Framework Laptop 12 Battery Replacement, Power down your laptop: 1 단계, 이미지 3개 중 2개 Framework Laptop 12 Battery Replacement, Power down your laptop: 1 단계, 이미지 3개 중 3개
    • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The laptop should be silent.
    • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
  2. Framework Laptop 12 Battery Replacement, Set your laptop down: 2 단계, 이미지 1개 중 1개
    • Set your Framework Laptop face-down on a clean work surface.
  3. Framework Laptop 12 Battery Replacement, Loosen the bottom screws: 3 단계, 이미지 2개 중 1개 Framework Laptop 12 Battery Replacement, Loosen the bottom screws: 3 단계, 이미지 2개 중 2개
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
    • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
  4. Framework Laptop 12 Battery Replacement, Flip your laptop over: 4 단계, 이미지 1개 중 1개
    • Flip your laptop over so it's face-up on your work surface.
  5. Framework Laptop 12 Battery Replacement, Open your laptop: 5 단계, 이미지 2개 중 1개 Framework Laptop 12 Battery Replacement, Open your laptop: 5 단계, 이미지 2개 중 2개
    • Open the laptop lid so that both the screen and the base lie flat on your work surface.
  6. Framework Laptop 12 Battery Replacement, Remove the Input Cover: 6 단계, 이미지 3개 중 1개 Framework Laptop 12 Battery Replacement, Remove the Input Cover: 6 단계, 이미지 3개 중 2개 Framework Laptop 12 Battery Replacement, Remove the Input Cover: 6 단계, 이미지 3개 중 3개
    • Use your fingers to grip the Input Cover in the hinge cutouts.
    • Lift upwards to swing the Input Cover up from the base of the laptop.
    • Magnets hold the Input Cover down, so you'll feel some resistance. If it feels stuck, check that you've fully loosened all the screws on the bottom of your laptop.
    • Remove the Input Cover.
  7. Framework Laptop 12 Battery Replacement, Loosen the battery screws: 7 단계, 이미지 1개 중 1개
    • Use your Framework Screwdriver to loosen the six captive T5 Torx screws securing the battery.
  8. Framework Laptop 12 Battery Replacement, Disconnect the battery: 8 단계, 이미지 2개 중 1개 Framework Laptop 12 Battery Replacement, Disconnect the battery: 8 단계, 이미지 2개 중 2개
    • Grab the orange battery tab with your fingers and lift straight up to disconnect the battery.
    • The battery connector can be tight, requiring some force. If it feels like part of the battery won't come up, check that the battery screws are fully loosened.
  9. Framework Laptop 12 Battery Replacement, Remove the battery: 9 단계, 이미지 2개 중 1개 Framework Laptop 12 Battery Replacement, Remove the battery: 9 단계, 이미지 2개 중 2개
    • Lift and remove the battery from the laptop.
  10. Framework Laptop 12 Battery Replacement, Disassembly complete: 10 단계, 이미지 1개 중 1개
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  11. Framework Laptop 12 Battery Replacement, Install the battery: 11 단계, 이미지 1개 중 1개
    • Lay the battery in its recess in the laptop.
  12. Framework Laptop 12 Battery Replacement: 12 단계, 이미지 2개 중 1개 Framework Laptop 12 Battery Replacement: 12 단계, 이미지 2개 중 2개
    • Use your finger to push the battery down near its connector to reconnect it.
  13. Framework Laptop 12 Battery Replacement: 13 단계, 이미지 1개 중 1개
    • Use your Framework Screwdriver to tighten the six captive T5 Torx screws to secure the battery.
    • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
  14. Framework Laptop 12 Battery Replacement, Install the Input Cover: 14 단계, 이미지 3개 중 1개 Framework Laptop 12 Battery Replacement, Install the Input Cover: 14 단계, 이미지 3개 중 2개 Framework Laptop 12 Battery Replacement, Install the Input Cover: 14 단계, 이미지 3개 중 3개
    • Angle the bottom edge of the Input Cover towards the base of the laptop.
    • Align and insert the bottom edge of the Input Cover into the base of the laptop.
    • Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
    • Lower the Input Cover's top edge onto the laptop until the magnets snap it in place.
    • Make sure the Input Cover sits neatly within the laptop frame and no corners are popping up.
  15. Framework Laptop 12 Battery Replacement, Close and flip your laptop: 15 단계, 이미지 2개 중 1개 Framework Laptop 12 Battery Replacement, Close and flip your laptop: 15 단계, 이미지 2개 중 2개
    • Close the laptop lid.
    • Flip your laptop face-down on a clean work surface.
  16. Framework Laptop 12 Battery Replacement, Tighten the bottom screws: 16 단계, 이미지 2개 중 1개 Framework Laptop 12 Battery Replacement, Tighten the bottom screws: 16 단계, 이미지 2개 중 2개
    • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop.
  17. Framework Laptop 12 Battery Replacement, Plug in your laptop: 17 단계, 이미지 1개 중 1개
    • The battery ships in shipping mode, so the laptop won't power on until you plug it in first.
    • Plug a power supply into any USB-C port on your laptop.
결론
You finished fixing your Framework Laptop!
Don't throw your battery in the trash. Click here to learn how to dispose of it properly.
If you need help, contact Framework support.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
309,604 평판
안내서 701개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,763개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 50
전체 시간: 542
