주요 콘텐츠로 건너뛰기
Framework Laptop 16 Speakers Replacement
필요한 것
  1. Framework Laptop 16 Speakers Replacement, Before you begin: 1 단계, 이미지 1개 중 1개
    • Unplug all cables and fully shut down your laptop.
  2. Framework Laptop 16 Speakers Replacement, Unlock the Input Modules: 2 단계, 이미지 3개 중 1개 Framework Laptop 16 Speakers Replacement, Unlock the Input Modules: 2 단계, 이미지 3개 중 2개 Framework Laptop 16 Speakers Replacement, Unlock the Input Modules: 2 단계, 이미지 3개 중 3개
    • Use your fingernail to pull out the two Input Module latches and unlock them.
    • The latch will show red if it's unlocked.
  3. Framework Laptop 16 Speakers Replacement, Remove the Touchpad Spacers: 3 단계, 이미지 3개 중 1개 Framework Laptop 16 Speakers Replacement, Remove the Touchpad Spacers: 3 단계, 이미지 3개 중 2개 Framework Laptop 16 Speakers Replacement, Remove the Touchpad Spacers: 3 단계, 이미지 3개 중 3개
    • Use your fingers to slide the Touchpad Spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the Touchpad Spacer off the laptop and remove it.
  4. Framework Laptop 16 Speakers Replacement: 4 단계, 이미지 3개 중 1개 Framework Laptop 16 Speakers Replacement: 4 단계, 이미지 3개 중 2개 Framework Laptop 16 Speakers Replacement: 4 단계, 이미지 3개 중 3개
    • Repeat the same procedure for the other touchpad spacer.
  5. Framework Laptop 16 Speakers Replacement, Remove the Touchpad Module: 5 단계, 이미지 3개 중 1개 Framework Laptop 16 Speakers Replacement, Remove the Touchpad Module: 5 단계, 이미지 3개 중 2개 Framework Laptop 16 Speakers Replacement, Remove the Touchpad Module: 5 단계, 이미지 3개 중 3개
    • Use your fingers to slide the Touchpad Module toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the Touchpad Module and remove it.
  6. Framework Laptop 16 Speakers Replacement, Remove the keyboard: 6 단계, 이미지 3개 중 1개 Framework Laptop 16 Speakers Replacement, Remove the keyboard: 6 단계, 이미지 3개 중 2개 Framework Laptop 16 Speakers Replacement, Remove the keyboard: 6 단계, 이미지 3개 중 3개
    • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
    • Grip the two pull tabs along the bottom of the keyboard and lift until its magnets release.
    • Remove the keyboard.
  7. Framework Laptop 16 Speakers Replacement, Remove the Input Modules: 7 단계, 이미지 3개 중 1개 Framework Laptop 16 Speakers Replacement, Remove the Input Modules: 7 단계, 이미지 3개 중 2개 Framework Laptop 16 Speakers Replacement, Remove the Input Modules: 7 단계, 이미지 3개 중 3개
    • Your Input Module(s) might be different, but the procedure to remove them is the same.
    • Grip the pull tab at the bottom of the Input Module and lift until its magnets release.
    • Remove the Input Module.
    • Repeat for any remaining Input Modules.
  8. Framework Laptop 16 Speakers Replacement, Disconnect the Mid Plate cable: 8 단계, 이미지 2개 중 1개 Framework Laptop 16 Speakers Replacement, Disconnect the Mid Plate cable: 8 단계, 이미지 2개 중 2개
    • Grip the black pull tab on the Mid Plate cable press connector.
    • Lift up to disconnect the Mid Plate cable.
  9. Framework Laptop 16 Speakers Replacement, Loosen the Mid Plate screws: 9 단계, 이미지 2개 중 1개 Framework Laptop 16 Speakers Replacement, Loosen the Mid Plate screws: 9 단계, 이미지 2개 중 2개
    • The Mid Plate screws are ordered from 2–17 (number 1 is the press connector). You don't have to follow the order, but you can use it to help keep track of the screws you've loosened.
    • Use your Framework Screwdriver to loosen the 16 captive T5 Torx screws securing the Mid Plate.
  10. Framework Laptop 16 Speakers Replacement, Remove the Mid Plate: 10 단계, 이미지 3개 중 1개 Framework Laptop 16 Speakers Replacement, Remove the Mid Plate: 10 단계, 이미지 3개 중 2개 Framework Laptop 16 Speakers Replacement, Remove the Mid Plate: 10 단계, 이미지 3개 중 3개
    • Use your fingers to lift the Mid Plate off the laptop and remove it.
  11. Framework Laptop 16 Speakers Replacement, Loosen the battery screws: 11 단계, 이미지 2개 중 1개 Framework Laptop 16 Speakers Replacement, Loosen the battery screws: 11 단계, 이미지 2개 중 2개
    • Use your Framework Screwdriver to loosen the three captive T5 Torx screws securing the battery.
  12. Framework Laptop 16 Speakers Replacement, Remove the battery: 12 단계, 이미지 3개 중 1개 Framework Laptop 16 Speakers Replacement, Remove the battery: 12 단계, 이미지 3개 중 2개 Framework Laptop 16 Speakers Replacement, Remove the battery: 12 단계, 이미지 3개 중 3개
    • Grip the black pull tab at the top of the battery and lift to disconnect the battery connector.
    • Remove the battery.
  13. Framework Laptop 16 Speakers Replacement, Disconnect the speaker: 13 단계, 이미지 2개 중 1개 Framework Laptop 16 Speakers Replacement, Disconnect the speaker: 13 단계, 이미지 2개 중 2개
    • Lift the speaker cable connector by its black pull tab and disconnect it.
  14. Framework Laptop 16 Speakers Replacement, Reroute the speaker cable: 14 단계, 이미지 3개 중 1개 Framework Laptop 16 Speakers Replacement, Reroute the speaker cable: 14 단계, 이미지 3개 중 2개 Framework Laptop 16 Speakers Replacement, Reroute the speaker cable: 14 단계, 이미지 3개 중 3개
    • The speaker cable is routed along the bottom edge of the laptop. The next three steps will demonstrate how to unclip it.
    • Starting at one speaker, use the flat end of a spudger, or your fingers, to lift the speaker cable out of its rubber clips.
  15. Framework Laptop 16 Speakers Replacement: 15 단계, 이미지 2개 중 1개 Framework Laptop 16 Speakers Replacement: 15 단계, 이미지 2개 중 2개
    • Slide the speaker cable out from under its screw hole peg in the frame.
  16. Framework Laptop 16 Speakers Replacement: 16 단계, 이미지 2개 중 1개 Framework Laptop 16 Speakers Replacement: 16 단계, 이미지 2개 중 2개
    • Repeat the last two steps across the length of the speaker cable until it's completely unclipped.
  17. Framework Laptop 16 Speakers Replacement, Remove the speaker screws: 17 단계, 이미지 2개 중 1개 Framework Laptop 16 Speakers Replacement, Remove the speaker screws: 17 단계, 이미지 2개 중 2개
    • Use your Framework Screwdriver to remove the two 2.0 mm‑long T5 Torx screws securing each speaker (four in total).
  18. Framework Laptop 16 Speakers Replacement, Remove the speakers: 18 단계, 이미지 3개 중 1개 Framework Laptop 16 Speakers Replacement, Remove the speakers: 18 단계, 이미지 3개 중 2개 Framework Laptop 16 Speakers Replacement, Remove the speakers: 18 단계, 이미지 3개 중 3개
  19. Framework Laptop 16 Speakers Replacement, Disassembly complete: 19 단계, 이미지 1개 중 1개
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  20. Framework Laptop 16 Speakers Replacement, Place the speakers: 20 단계, 이미지 3개 중 1개 Framework Laptop 16 Speakers Replacement, Place the speakers: 20 단계, 이미지 3개 중 2개 Framework Laptop 16 Speakers Replacement, Place the speakers: 20 단계, 이미지 3개 중 3개
    • Align the speakers over their alignment pegs and press them down into place.
  21. Framework Laptop 16 Speakers Replacement, Install the speaker screws: 21 단계, 이미지 2개 중 1개 Framework Laptop 16 Speakers Replacement, Install the speaker screws: 21 단계, 이미지 2개 중 2개
    • Be very careful replacing these screws, as it's easy to damage their posts and prevent the screws from fully tightening. Don't overtighten the screws—just tighten them until they're snug.
    • Use your Framework Screwdriver to install the two 2.0 mm‑long T5 Torx screws securing each speaker (four in total).
  22. Framework Laptop 16 Speakers Replacement, Reroute the speaker cable: 22 단계, 이미지 3개 중 1개 Framework Laptop 16 Speakers Replacement, Reroute the speaker cable: 22 단계, 이미지 3개 중 2개 Framework Laptop 16 Speakers Replacement, Reroute the speaker cable: 22 단계, 이미지 3개 중 3개
    • Use the flat end of your Framework Screwdriver to push the speaker cable back into its clips along the bottom edge of the laptop.
  23. Framework Laptop 16 Speakers Replacement, Connect the speaker: 23 단계, 이미지 2개 중 1개 Framework Laptop 16 Speakers Replacement, Connect the speaker: 23 단계, 이미지 2개 중 2개
    • Press the speaker cable connector onto its socket to connect it.
  24. Framework Laptop 16 Speakers Replacement, Install the battery: 24 단계, 이미지 3개 중 1개 Framework Laptop 16 Speakers Replacement, Install the battery: 24 단계, 이미지 3개 중 2개 Framework Laptop 16 Speakers Replacement, Install the battery: 24 단계, 이미지 3개 중 3개
    • Align the battery connector over its socket and lay the battery into its well.
    • Lightly press the battery down to connect it.
  25. Framework Laptop 16 Speakers Replacement, Tighten the battery screws: 25 단계, 이미지 2개 중 1개 Framework Laptop 16 Speakers Replacement, Tighten the battery screws: 25 단계, 이미지 2개 중 2개
    • Use your Framework Screwdriver to tighten the three captive T5 Torx screws securing the battery.
  26. Framework Laptop 16 Speakers Replacement, Place the Mid Plate: 26 단계, 이미지 3개 중 1개 Framework Laptop 16 Speakers Replacement, Place the Mid Plate: 26 단계, 이미지 3개 중 2개 Framework Laptop 16 Speakers Replacement, Place the Mid Plate: 26 단계, 이미지 3개 중 3개
    • Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
  27. Framework Laptop 16 Speakers Replacement, Tighten the Mid Plate screws: 27 단계, 이미지 2개 중 1개 Framework Laptop 16 Speakers Replacement, Tighten the Mid Plate screws: 27 단계, 이미지 2개 중 2개
    • Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly.
  28. Framework Laptop 16 Speakers Replacement, Connect the Mid Plate cable: 28 단계, 이미지 2개 중 1개 Framework Laptop 16 Speakers Replacement, Connect the Mid Plate cable: 28 단계, 이미지 2개 중 2개
    • Align the Mid Plate cable press connector over its socket and press down to connect it.
  29. Framework Laptop 16 Speakers Replacement, Remove the numpad: 29 단계, 이미지 3개 중 1개 Framework Laptop 16 Speakers Replacement, Remove the numpad: 29 단계, 이미지 3개 중 2개 Framework Laptop 16 Speakers Replacement, Remove the numpad: 29 단계, 이미지 3개 중 3개
    • The numpad is held in place with strong magnets. Apply gradually increasing force to avoid having the numpad violently eject.
    • Grip the pull tab at the bottom of the numpad.
    • Lift the pull tab until the numpad magnets release.
    • Remove the numpad.
    • During reassembly, make sure the numpad is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  30. Framework Laptop 16 Speakers Replacement, Install the keyboard: 30 단계, 이미지 3개 중 1개 Framework Laptop 16 Speakers Replacement, Install the keyboard: 30 단계, 이미지 3개 중 2개 Framework Laptop 16 Speakers Replacement, Install the keyboard: 30 단계, 이미지 3개 중 3개
    • Align the top edge of the keyboard with the top edge of the laptop.
    • Lay the keyboard on the laptop and let the magnets pull the keyboard into place
    • Make sure the keyboard is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  31. Framework Laptop 16 Speakers Replacement, Install the Touchpad Module: 31 단계, 이미지 2개 중 1개 Framework Laptop 16 Speakers Replacement, Install the Touchpad Module: 31 단계, 이미지 2개 중 2개
    • Place the Touchpad Module flat on its cutout so its clips are properly aligned.
    • Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  32. Framework Laptop 16 Speakers Replacement, Install the Touchpad Spacers: 32 단계, 이미지 3개 중 1개 Framework Laptop 16 Speakers Replacement, Install the Touchpad Spacers: 32 단계, 이미지 3개 중 2개 Framework Laptop 16 Speakers Replacement, Install the Touchpad Spacers: 32 단계, 이미지 3개 중 3개
    • Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly.
    • Slide the Touchpad Spacer towards the top of the laptop to secure it.
    • Repeat the same procedure for the other Touchpad Spacer.
결론
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
212,512 평판
안내서 1,037개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 27
전체 시간: 37
