주요 콘텐츠로 건너뛰기
Framework Laptop 16" Display Replacement
필요한 것
  1. Framework Laptop 16" Display Replacement, Before you begin: 1 단계, 이미지 2개 중 1개 Framework Laptop 16" Display Replacement, Before you begin: 1 단계, 이미지 2개 중 2개
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
  2. Framework Laptop 16" Display Replacement, Create a gap: 2 단계, 이미지 3개 중 1개 Framework Laptop 16" Display Replacement, Create a gap: 2 단계, 이미지 3개 중 2개 Framework Laptop 16" Display Replacement, Create a gap: 2 단계, 이미지 3개 중 3개
    • The bezel is secured with magnets!
    • Slide your fingernail under the inside edge of either bottom corner of the bezel.
    • Pull the bezel away from the screen to release the first few magnets.
  3. Framework Laptop 16" Display Replacement, Remove the bezel: 3 단계, 이미지 3개 중 1개 Framework Laptop 16" Display Replacement, Remove the bezel: 3 단계, 이미지 3개 중 2개 Framework Laptop 16" Display Replacement, Remove the bezel: 3 단계, 이미지 3개 중 3개
    • Lift the bezel around the perimeter of the screen until all of its magnets are released.
    • Remove the bezel.
  4. Framework Laptop 16" Display Replacement, Remove the display screws: 4 단계, 이미지 3개 중 1개 Framework Laptop 16" Display Replacement, Remove the display screws: 4 단계, 이미지 3개 중 2개 Framework Laptop 16" Display Replacement, Remove the display screws: 4 단계, 이미지 3개 중 3개
    • Use a T5 Torx screwdriver to remove the four 2.4 mm‑long screws securing the display.
    • During reassembly, support the screen frame with your other hand as you reinsert screws to prevent the laptop from accidentally tipping over.
  5. Framework Laptop 16" Display Replacement, Disconnect the display: 5 단계, 이미지 3개 중 1개 Framework Laptop 16" Display Replacement, Disconnect the display: 5 단계, 이미지 3개 중 2개 Framework Laptop 16" Display Replacement, Disconnect the display: 5 단계, 이미지 3개 중 3개
    • Grab the display and pull it straight off the screen frame to free it from its alignment pegs.
    • Don't pull the display too far from the frame, as it's still attached by a cable.
    • Flip the front of the display down and rest it on the keyboard.
  6. Framework Laptop 16" Display Replacement: 6 단계, 이미지 2개 중 1개 Framework Laptop 16" Display Replacement: 6 단계, 이미지 2개 중 2개
    • Use your fingers to flip up the plastic tab and access the connector underneath.
  7. Framework Laptop 16" Display Replacement: 7 단계, 이미지 2개 중 1개 Framework Laptop 16" Display Replacement: 7 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to lift up the metal locking tab over the display connector.
  8. Framework Laptop 16" Display Replacement, Remove the display: 8 단계, 이미지 3개 중 1개 Framework Laptop 16" Display Replacement, Remove the display: 8 단계, 이미지 3개 중 2개 Framework Laptop 16" Display Replacement, Remove the display: 8 단계, 이미지 3개 중 3개
    • Grip the display cable where it meets the connector head.
    • Slide the connector straight out of its socket to disconnect it.
    • Remove the display.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
다른 2명이 해당 안내서를 완성하였습니다.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
215,526 평판
안내서 1,046개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,803개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 21
지난 30일: 68
전체 시간: 1,251
