주요 콘텐츠로 건너뛰기
Framework Laptop 16" Keyboard Replacement
  1. Framework Laptop 16" Keyboard Replacement, Before you begin: 1 단계, 이미지 2개 중 1개 Framework Laptop 16" Keyboard Replacement, Before you begin: 1 단계, 이미지 2개 중 2개
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
  2. Framework Laptop 16" Keyboard Replacement, Unlock the Input Modules: 2 단계, 이미지 3개 중 1개 Framework Laptop 16" Keyboard Replacement, Unlock the Input Modules: 2 단계, 이미지 3개 중 2개 Framework Laptop 16" Keyboard Replacement, Unlock the Input Modules: 2 단계, 이미지 3개 중 3개
    • Use your fingernail to pull out the two Input Module latches and unlock them.
    • The latch will show red if it's unlocked.
  3. Framework Laptop 16" Keyboard Replacement, Remove the touchpad spacers: 3 단계, 이미지 3개 중 1개 Framework Laptop 16" Keyboard Replacement, Remove the touchpad spacers: 3 단계, 이미지 3개 중 2개 Framework Laptop 16" Keyboard Replacement, Remove the touchpad spacers: 3 단계, 이미지 3개 중 3개
    • Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the touchpad spacer off the laptop and remove it.
  4. Framework Laptop 16" Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Repeat the same procedure for the other touchpad spacer.
  5. Framework Laptop 16" Keyboard Replacement, Remove the touchpad: 5 단계, 이미지 3개 중 1개 Framework Laptop 16" Keyboard Replacement, Remove the touchpad: 5 단계, 이미지 3개 중 2개 Framework Laptop 16" Keyboard Replacement, Remove the touchpad: 5 단계, 이미지 3개 중 3개
    • Use your fingers to slide the touchpad toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the touchpad and remove it.
    • During reassembly, perform the following:
    • Place the touchpad flat on its cutout so its clips are properly aligned.
    • Press the touchpad down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  6. Framework Laptop 16" Keyboard Replacement, Remove the keyboard: 6 단계, 이미지 3개 중 1개 Framework Laptop 16" Keyboard Replacement, Remove the keyboard: 6 단계, 이미지 3개 중 2개 Framework Laptop 16" Keyboard Replacement, Remove the keyboard: 6 단계, 이미지 3개 중 3개
    • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
    • Grip the two pull tabs along the bottom of the keyboard.
    • Lift the pull tabs until the keyboard magnets release.
    • Remove the keyboard.
    • During reassembly, make sure the keyboard is seated properly on its alignment pegs and sits evenly with the edges of the laptop.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
163,333 평판
안내서 769개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,554개를 작성함
댓글 한 개
this is a pretty funny guide, i genuinely like that it exists lol, only thing is you dont need to shut down your system; the keyboard, trackpad, numpad/macropad, spacers, LED matrix strips, etc, can be hot-swapped. same with the input modules
ChazIsBuns - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 47
전체 시간: 801
