주요 콘텐츠로 건너뛰기
Framework Laptop 16" Mainboard Replacement
필요한 것
  1. Framework Laptop 16" Mainboard Replacement, Before you begin: 1 단계, 이미지 2개 중 1개 Framework Laptop 16" Mainboard Replacement, Before you begin: 1 단계, 이미지 2개 중 2개
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
    • Framework recommends that you put your laptop into battery disconnect mode in the BIOS whenever removing the battery. Read how to do that here.
    • To disable this mode, click here.
  2. Framework Laptop 16" Mainboard Replacement, Unlock the expansion cards: 2 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement, Unlock the expansion cards: 2 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement, Unlock the expansion cards: 2 단계, 이미지 3개 중 3개
    • Flip your laptop over and find the two locking tabs beneath the expansion cards.
    • Pull the locking tabs down to unlock the rows of expansion cards above them.
    • The locking tab will show red when it's unlocked.
  3. Framework Laptop 16" Mainboard Replacement, Remove the expansion card: 3 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement, Remove the expansion card: 3 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement, Remove the expansion card: 3 단계, 이미지 3개 중 3개
    • Insert your fingernail over the white rubber lip along the inner edge of the expansion card.
    • Pull the card away from the laptop to disconnect it.
    • This might take some initial force. If you're having trouble, make sure the locking tab is properly unlocked.
    • Slide the card completely off its rail and remove it.
    • Repeat for all of the expansion cards.
    • During reassembly, align the new card on the rail and push it in until it sits evenly with the edge of the laptop.
  4. Framework Laptop 16" Mainboard Replacement, Unlock the Input Modules: 4 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement, Unlock the Input Modules: 4 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement, Unlock the Input Modules: 4 단계, 이미지 3개 중 3개
    • Use your fingernail to pull out the two Input Module latches and unlock them.
    • The latch will show red if it's unlocked.
  5. Framework Laptop 16" Mainboard Replacement, Remove the touchpad spacers: 5 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement, Remove the touchpad spacers: 5 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement, Remove the touchpad spacers: 5 단계, 이미지 3개 중 3개
    • Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the touchpad spacer off the laptop and remove it.
  6. Framework Laptop 16" Mainboard Replacement: 6 단계, 이미지 1개 중 1개
    • Repeat the same procedure for the other touchpad spacer.
  7. Framework Laptop 16" Mainboard Replacement, Remove the touchpad: 7 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement, Remove the touchpad: 7 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement, Remove the touchpad: 7 단계, 이미지 3개 중 3개
    • Use your fingers to slide the touchpad toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the touchpad and remove it.
    • During reassembly, perform the following:
    • Place the touchpad flat on its cutout so its clips are properly aligned.
    • Press the touchpad down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  8. Framework Laptop 16" Mainboard Replacement, Remove the keyboard: 8 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement, Remove the keyboard: 8 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement, Remove the keyboard: 8 단계, 이미지 3개 중 3개
    • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
    • Grip the two pull tabs along the bottom of the keyboard.
    • Lift the pull tabs until the keyboard magnets release.
    • Remove the keyboard.
    • During reassembly, make sure the keyboard is seated properly on its alignment pegs and sits evenly with the edges of the laptop.
  9. Framework Laptop 16" Mainboard Replacement, Remove the numpad: 9 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement, Remove the numpad: 9 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement, Remove the numpad: 9 단계, 이미지 3개 중 3개
    • The numpad is held in place with strong magnets. Apply gradually increasing force to avoid having the numpad violently eject.
    • Grip the pull tab at the bottom of the numpad.
    • Lift the pull tab until the numpad magnets release.
    • Remove the numpad.
    • During reassembly, make sure the numpad is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  10. Framework Laptop 16" Mainboard Replacement, Disconnect the midframe cable: 10 단계, 이미지 2개 중 1개 Framework Laptop 16" Mainboard Replacement, Disconnect the midframe cable: 10 단계, 이미지 2개 중 2개
    • Grip the black pull tab on the midframe cable press connector.
    • Lift up to disconnect the midframe cable.
  11. Framework Laptop 16" Mainboard Replacement, Loosen the midframe screws: 11 단계, 이미지 2개 중 1개 Framework Laptop 16" Mainboard Replacement, Loosen the midframe screws: 11 단계, 이미지 2개 중 2개
    • The midframe screws are ordered from 2–17 (number 1 is the press connector). You don't have to follow the order, but you can use it to help keep track of the screws you've loosened.
    • Use a T5 Torx screwdriver to loosen the 16 captive screws securing the midframe.
    • During reassembly, follow the order (starting with 2) to reinstall the screws across the midframe evenly.
  12. Framework Laptop 16" Mainboard Replacement, Remove the midframe: 12 단계, 이미지 2개 중 1개 Framework Laptop 16" Mainboard Replacement, Remove the midframe: 12 단계, 이미지 2개 중 2개
    • Use your fingernail to lift the bottom edge of the midframe enough to grip it with your fingers.
  13. Framework Laptop 16" Mainboard Replacement: 13 단계, 이미지 2개 중 1개 Framework Laptop 16" Mainboard Replacement: 13 단계, 이미지 2개 중 2개
    • Lift the midframe off the laptop and remove it.
    • During reassembly, make sure the midframe sits evenly on its alignment pegs before tightening the screws.
  14. Framework Laptop 16" Mainboard Replacement, Loosen the battery screws: 14 단계, 이미지 2개 중 1개 Framework Laptop 16" Mainboard Replacement, Loosen the battery screws: 14 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to loosen the three captive screws securing the battery.
  15. Framework Laptop 16" Mainboard Replacement, Remove the battery: 15 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement, Remove the battery: 15 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement, Remove the battery: 15 단계, 이미지 3개 중 3개
    • Grip the black pull tab at the top of the battery.
    • Lift the pull tab to disconnect the battery connector.
    • Remove the battery.
  16. Framework Laptop 16" Mainboard Replacement, Remove the SSD screw: 16 단계, 이미지 2개 중 1개 Framework Laptop 16" Mainboard Replacement, Remove the SSD screw: 16 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to remove the 2 mm‑long screw securing the SSD.
    • The SSD might pop up at a shallow angle when you remove the screw.
  17. Framework Laptop 16" Mainboard Replacement, Remove the SSD: 17 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement, Remove the SSD: 17 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement, Remove the SSD: 17 단계, 이미지 3개 중 3개
    • Grip the end of the SSD with the screw hole and slide it out of its socket.
    • Remove the SSD.
    • If you're installing a secondary M.2 2230 SSD, remove the 2 mm‑long screw next to the gray thermal pad and follow the same removal procedure.
    • During reassembly, insert the SSD at a shallow angle into its socket, and hold it flat to the laptop while you reinsert its screw.
  18. Framework Laptop 16" Mainboard Replacement, Remove the RAM: 18 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement, Remove the RAM: 18 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement, Remove the RAM: 18 단계, 이미지 3개 중 3개
    • Push the two metal arms on each side of the RAM stick outward until they disengage and the stick pops up at a shallow angle.
    • Repeat for the other RAM stick.
  19. Framework Laptop 16" Mainboard Replacement: 19 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement: 19 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement: 19 단계, 이미지 3개 중 3개
    • Slide the RAM stick out of its socket and remove it.
    • During reassembly, insert the RAM sticks into their sockets at a slight downward angle, then push down firmly until both metal arms lock the sticks in place.
  20. Framework Laptop 16" Mainboard Replacement, Loosen the Wi-Fi card screw: 20 단계, 이미지 2개 중 1개 Framework Laptop 16" Mainboard Replacement, Loosen the Wi-Fi card screw: 20 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to loosen the captive screw securing Wi-Fi card.
    • The Wi-Fi card might pop up at a shallow angle when you loosen the screw.
  21. Framework Laptop 16" Mainboard Replacement, Remove the Wi-Fi card: 21 단계, 이미지 2개 중 1개 Framework Laptop 16" Mainboard Replacement, Remove the Wi-Fi card: 21 단계, 이미지 2개 중 2개
    • Slide the clear Wi-Fi card cover straight off the card and remove it.
  22. Framework Laptop 16" Mainboard Replacement: 22 단계, 이미지 2개 중 1개 Framework Laptop 16" Mainboard Replacement: 22 단계, 이미지 2개 중 2개
    • Grip the end of the Wi-Fi card with the screw hole and slide it out of its socket.
    • Don't pull the Wi-Fi card too far from its socket, as it's still connected by two cables.
  23. Framework Laptop 16" Mainboard Replacement: 23 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement: 23 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement: 23 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger under one of the coaxial connectors, where the cable meets the metal head.
    • Lift the spudger straight up to disconnect the coaxial cable.
    • Repeat for the other coaxial cable and remove the Wi-Fi card.
    • During reassembly, refer to the arrows on the Wi-Fi card for which cable (black or white) a connector belongs to.
  24. Framework Laptop 16" Mainboard Replacement, Lift the interposer door: 24 단계, 이미지 2개 중 1개 Framework Laptop 16" Mainboard Replacement, Lift the interposer door: 24 단계, 이미지 2개 중 2개
    • Lift the interposer door by its black pull tab and let it rest upright.
  25. Framework Laptop 16" Mainboard Replacement, Loosen the interposer screws: 25 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement, Loosen the interposer screws: 25 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement, Loosen the interposer screws: 25 단계, 이미지 3개 중 3개
    • If you have the graphics module installed, your interposer will have four screws. Otherwise, you'll have three screws.
    • Lift the pull tab on the interposer and let it rest vertically to access all of its screws.
    • Use a T5 Torx screwdriver to loosen the three captive screws securing the interposer.
    • If you have the graphics module, use a T5 Torx screwdriver to loosen the four captive screws securing the interposer.
  26. Framework Laptop 16" Mainboard Replacement, Remove the interposer: 26 단계, 이미지 2개 중 1개 Framework Laptop 16" Mainboard Replacement, Remove the interposer: 26 단계, 이미지 2개 중 2개
    • Lift the interposer by its pull tab and remove it.
  27. Framework Laptop 16" Mainboard Replacement, Loosen the expansion bay screws: 27 단계, 이미지 2개 중 1개 Framework Laptop 16" Mainboard Replacement, Loosen the expansion bay screws: 27 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to loosen the two captive screws securing the expansion bay.
    • Close the interposer door before continuing.
  28. Framework Laptop 16" Mainboard Replacement, Remove the Expansion Bay module: 28 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement, Remove the Expansion Bay module: 28 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement, Remove the Expansion Bay module: 28 단계, 이미지 3개 중 3개
    • Slide the Expansion Bay module out of the laptop and remove it.
    • The module should slide out easily. If you feel any resistance, check if the screws holding it in place are fully loosened.
  29. Framework Laptop 16" Mainboard Replacement, Disconnect the fingerprint sensor: 29 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement, Disconnect the fingerprint sensor: 29 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement, Disconnect the fingerprint sensor: 29 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger, or a clean fingernail, to lift up the locking tab on the fingerprint sensor ZIF connector.
  30. Framework Laptop 16" Mainboard Replacement: 30 단계, 이미지 2개 중 1개 Framework Laptop 16" Mainboard Replacement: 30 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to grip the blue pull tab and slide the fingerprint sensor cable straight out of its socket.
  31. Framework Laptop 16" Mainboard Replacement: 31 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement: 31 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement: 31 단계, 이미지 3개 중 3개
    • The fingerprint sensor cable is lightly adhered to the laptop frame.
    • Use your fingers to peel the fingerprint sensor cable away from the frame and separate the adhesive.
    • During reassembly, if your adhesive is still sticky, press the cable to the frame to re-adhere it. Otherwise, use double-sided tape to replace the adhesive.
  32. Framework Laptop 16" Mainboard Replacement, Remove the ventilation plate: 32 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement, Remove the ventilation plate: 32 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement, Remove the ventilation plate: 32 단계, 이미지 3개 중 3개
    • The ventilation plate is held in place with magnets.
    • Lift the bottom of the ventilation plate and pull it away from the laptop until the magnets release.
    • Remove the ventilation plate.
  33. Framework Laptop 16" Mainboard Replacement, Disconnect the speaker: 33 단계, 이미지 2개 중 1개 Framework Laptop 16" Mainboard Replacement, Disconnect the speaker: 33 단계, 이미지 2개 중 2개
    • Lift the speaker cable connector by its black pull tab and disconnect it.
  34. Framework Laptop 16" Mainboard Replacement, Disconnect the display: 34 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement, Disconnect the display: 34 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement, Disconnect the display: 34 단계, 이미지 3개 중 3개
    • Lift the two display connectors by their black pull tabs to disconnect them.
  35. Framework Laptop 16" Mainboard Replacement, Reroute the cables: 35 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement, Reroute the cables: 35 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement, Reroute the cables: 35 단계, 이미지 3개 중 3개
    • Lift the display and Wi-Fi card cables out of their slot in the frame enough to give room for the mainboard to lift straight up.
    • During reassembly, make sure the cables are routed properly in their slot so the midframe can sit flat on the frame.
  36. Framework Laptop 16" Mainboard Replacement, Remove the mainboard screws: 36 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement, Remove the mainboard screws: 36 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement, Remove the mainboard screws: 36 단계, 이미지 3개 중 3개
    • Lift up the interposer door to reveal the screw underneath.
    • The mainboard screws are ordered from 1–6. You don't have to follow the order, but you can use it to help keep track of the screws you've removed.
    • Use a T5 Torx screwdriver to remove the six 2 mm‑long screws securing the mainboard.
  37. Framework Laptop 16" Mainboard Replacement, Remove the mainboard: 37 단계, 이미지 3개 중 1개 Framework Laptop 16" Mainboard Replacement, Remove the mainboard: 37 단계, 이미지 3개 중 2개 Framework Laptop 16" Mainboard Replacement, Remove the mainboard: 37 단계, 이미지 3개 중 3개
    • Grab the mainboard by the curving pipes of its heatsink.
    • Lift the mainboard off its alignment pegs and remove it.
    • During reassembly, make sure all of the cables are above the mainboard before securing it back to the frame.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
215,105 평판
안내서 1,046개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 52
전체 시간: 1,635
