주요 콘텐츠로 건너뛰기
Free Wheelchair Mission GEN 1 Lawn Chair Replacement
필요한 것
  1. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Cushion: 1 단계, 이미지 2개 중 1개 Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Cushion: 1 단계, 이미지 2개 중 2개
    • Locate the four straps on each corner of the cushion.
    • Untie each of the straps and remove the cushion from the chair.
  2. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Axle: 2 단계, 이미지 3개 중 1개 Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Axle: 2 단계, 이미지 3개 중 2개 Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Axle: 2 단계, 이미지 3개 중 3개
    • Turn the chair around and locate the two base plates that hold the axle to the back of the chair.
    • There are two screws on each of the plates that connect the chair to the axle.
    • Hold the nut with the pliers. In the other hand, use the 10mm wrench to remove the screw.
  3. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Screws From Axle: 3 단계, 이미지 1개 중 1개
    • Remove both of the screws from each of the axle plates to free the chair from the axle.
    • Make sure too keep track of which bolts belong to certain parts of the wheelchair. You do not want to loose track of where each bolt belongs.
  4. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Unfasten Brakes: 4 단계, 이미지 1개 중 1개
    • Locate both of the brakes. They are each located on the front of the chair between the rear tire and the frame.
    • There are two screws connecting each of the brakes to the frame.
    • Remove both of the screws from the frame using the 10mm wrench and pair of pliers.
  5. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Brakes: 5 단계, 이미지 2개 중 1개 Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Brakes: 5 단계, 이미지 2개 중 2개
    • Remove the brakes from the frame.
    • Repeat with the brake on the other side of the wheelchair.
  6. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Unfasten Front Frame and Castor Wheel: 6 단계, 이미지 2개 중 1개 Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Unfasten Front Frame and Castor Wheel: 6 단계, 이미지 2개 중 2개
    • Locate the screws that hold the back frame, chair, castor wheel, and front frame together.
    • There is one screw on each side of the chair immediately above where the brakes are located.
    • Remove both of these screws using the 10mm wrench and a pair of pliers.
  7. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Separate Chair from Front Frame: 7 단계, 이미지 1개 중 1개
    • Remove the front frame and each of the castor wheels from the wheelchair.
  8. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Lawn Chair: 8 단계, 이미지 1개 중 1개
    • Remove the lawn chair from the back frame by lifting it up.
결론
To place a new lawn chair into the wheelchair, follow these instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
David Schaeffer
회원 가입일: 04/19/13
118 평판
안내서 1개를 작성함
Cal Poly, Team 14-7, Maness Spring 2013 Cal Poly, Team 14-7, Maness Spring 2013 회원
CPSU-MANESS-S13S14G7
5 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 15
전체 시간: 1,197
