주요 콘텐츠로 건너뛰기
Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement
필요한 것
  1. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement, Rear Wheel Axle: 1 단계, 이미지 1/2 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement, Rear Wheel Axle: 1 단계, 이미지 2/2
    • Attach the 19mm socket wrench to the head of the bolt in the middle of the wheel
    • With the other hand use the 19mm crescent wrench to hold the nut in place
    • While holding the 19mm crescent wrench in place, use socket wrench to unscrew the bolt
    • The Free Wheelchair Mission Multi-Purpose Tool can be used in place of the 19mm socket wrench
    • Remove the wheel from the axle
  2. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 2 단계, 이미지 1/2 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 2 단계, 이미지 2/2
    • Unscrew the nut holding the bolt and wheel together using your hands.
    • It might be necessary to loosen the nut with a 19 mm crescent wrench and the multi purpose tool
    • Repeat step on other wheel
    • Make sure to keep all corresponding nuts and bolts together to prevent mixup when reassembling the axle
  3. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 3 단계, 이미지 1/2 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 3 단계, 이미지 2/2
    • Locate the two baseplates on the back of the wheelchair holding the axle in place
  4. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 4 단계, 이미지 1/3 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 4 단계, 이미지 2/3 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 4 단계, 이미지 3/3
    • Using the pliers to hold the bolt in place, use the 10mm wrench to remove one bolt from the baseplate.
    • Repeat above step on second bolt
    • Repeat the process on the other baseplate, once one baseplate is loose from the chair and frame,
  5. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 5 단계, 이미지 1/3 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 5 단계, 이미지 2/3 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 5 단계, 이미지 3/3
    • Once both baseplates are loosened from the chair, pull the axle off from the wheelchair
    • The axle should come off easily
    • Slide the baseplates off of the axle
결론
To reassemble the axle to the wheelchair, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Mike Sevilla
회원 가입일: 04/05/13
348 평판
안내서 3개 작성하였습니다
Cal Poly, Team 14-7, Maness Spring 2013 Cal Poly, Team 14-7, Maness Spring 2013 회원
CPSU-MANESS-S13S14G7
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 1,489
