필요한 것
Align the crossbar (with the hole in the center) with the screw holes on the bottom of one frame piece.
Attach the crossbar to the left frame piece with two [2] frame nuts and bolts.
Repeat on the opposite frame piece.
Slide a footrest socket over the rail located near the front of the seat.
Insert a footrest through the bottom of the footrest socket.
Secure the footrest with a bolt above and below the socket.
Adjust the footrest socket to your desired height.
Align the socket's bolt with the nearest hole in the rail, and tighten the bolt.
Repeat this step on the opposite rail.
To disasemble your device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
