주요 콘텐츠로 건너뛰기
Free Wheelchair Mission GEN 2 Assembly
필요한 것
  1. Free Wheelchair Mission GEN 2 Assembly, Free Wheelchair Mission GEN 2 Assembly: 1 단계, 이미지 1/3 Free Wheelchair Mission GEN 2 Assembly, Free Wheelchair Mission GEN 2 Assembly: 1 단계, 이미지 2/3 Free Wheelchair Mission GEN 2 Assembly, Free Wheelchair Mission GEN 2 Assembly: 1 단계, 이미지 3/3
    • Align the crossbar (with the hole in the center) with the screw holes on the bottom of one frame piece.
    • Attach the crossbar to the left frame piece with two [2] frame nuts and bolts.
    • Repeat on the opposite frame piece.
  2. Free Wheelchair Mission GEN 2 Assembly: 2 단계, 이미지 1/3 Free Wheelchair Mission GEN 2 Assembly: 2 단계, 이미지 2/3 Free Wheelchair Mission GEN 2 Assembly: 2 단계, 이미지 3/3
    • Align the second crossbar with the holes on the back of the frame.
    • This crossbar has two square holes on either side.
    • Attach the crossbar to the frame using four [4] frame nuts and bolts.
  3. Free Wheelchair Mission GEN 2 Assembly: 3 단계, 이미지 1/3 Free Wheelchair Mission GEN 2 Assembly: 3 단계, 이미지 2/3 Free Wheelchair Mission GEN 2 Assembly: 3 단계, 이미지 3/3
    • Align the left (L) frame piece with the brake hole on the left frame piece.
    • Insert and tighten using one [1] brake bolt.
    • Repeat using the right (R) brake with the right frame piece.
  4. Free Wheelchair Mission GEN 2 Assembly: 4 단계, 이미지 1/2 Free Wheelchair Mission GEN 2 Assembly: 4 단계, 이미지 2/2
    • Slide the ring-shaped piece of one castor bearing onto the axle of one castor.
    • Slide the metal tube piece onto the axle of the castor.
    • Repeat for the second castor.
  5. Free Wheelchair Mission GEN 2 Assembly: 5 단계, 이미지 1/3 Free Wheelchair Mission GEN 2 Assembly: 5 단계, 이미지 2/3 Free Wheelchair Mission GEN 2 Assembly: 5 단계, 이미지 3/3
    • Slide another ring shaped bearing piece into the castor hole on the frame.
    • Insert the entire castor piece (castor, ring, and tube) into the opposite side of the hole.
    • Secure the castor and bearing pieces with a castor bolt.
    • Repeat on the opposite side of the frame.
  6. Free Wheelchair Mission GEN 2 Assembly: 6 단계, 이미지 1/3 Free Wheelchair Mission GEN 2 Assembly: 6 단계, 이미지 2/3 Free Wheelchair Mission GEN 2 Assembly: 6 단계, 이미지 3/3
    • Insert an axle bolt through the center of a rear wheel.
    • Insert the axle bolt with wheel into the axle hole on the frame.
    • Tighten the axle bolt.
    • Secure the wheel with a bolt on the opposite side of the hole.
    • Repeat on the opposite side of the frame to attach the other wheel.
  7. Free Wheelchair Mission GEN 2 Assembly: 7 단계, 이미지 1/3 Free Wheelchair Mission GEN 2 Assembly: 7 단계, 이미지 2/3 Free Wheelchair Mission GEN 2 Assembly: 7 단계, 이미지 3/3
    • Slide each handle into the respective slot on the top of the wheelchair.
    • Adjust the handles up or down to your desired height.
    • Secure the handles in place with one bolt and nut for each side.
  8. Free Wheelchair Mission GEN 2 Assembly: 8 단계, 이미지 1/2 Free Wheelchair Mission GEN 2 Assembly: 8 단계, 이미지 2/2
    • Insert the remaining crossbar between the handles, and align the holes on both sides.
    • Secure the crossbar with four [4] blue tipped bolts and rubber tipped nuts (two on each side).
  9. Free Wheelchair Mission GEN 2 Assembly: 9 단계, 이미지 1/2 Free Wheelchair Mission GEN 2 Assembly: 9 단계, 이미지 2/2
    • Orient the plastic seat with the smooth side up.
    • The rear strap can be attached to the seat in one of three positions in order to accommodate for people of different heights.
    • Loop the straps over the bars of the frame on either side.
    • Rotate the wheelchair onto its back side.
    • Secure the seat by tying each strap together.
    • Make sure that the straps are tied tightly so that the seat does not fall off the wheelchair.
  10. Free Wheelchair Mission GEN 2 Assembly: 10 단계, 이미지 1/2 Free Wheelchair Mission GEN 2 Assembly: 10 단계, 이미지 2/2
    • Reorient the chair so it is upright.
    • Place the seat cushion on top of the plastic seat with the angled side in front.
  11. Free Wheelchair Mission GEN 2 Assembly: 11 단계, 이미지 1/1
    • Place the bottom of the backrest against the back of the seat cushion.
    • Loop each strap behind the vertical bars of the frame.
    • Secure the backrest by tying each strap together.
    • Make sure that the straps are tied tightly so that the backrest does not fall off the wheelchair.
  12. Free Wheelchair Mission GEN 2 Assembly: 12 단계, 이미지 1/3 Free Wheelchair Mission GEN 2 Assembly: 12 단계, 이미지 2/3 Free Wheelchair Mission GEN 2 Assembly: 12 단계, 이미지 3/3
    • Slide a footrest socket over the rail located near the front of the seat.
    • Insert a footrest through the bottom of the footrest socket.
    • Secure the footrest with a bolt above and below the socket.
    • Adjust the footrest socket to your desired height.
    • Align the socket's bolt with the nearest hole in the rail, and tighten the bolt.
    • Repeat this step on the opposite rail.
  13. Free Wheelchair Mission GEN 2 Assembly: 13 단계, 이미지 1/1
  14. Free Wheelchair Mission GEN 2 Assembly: 14 단계, 이미지 1/1
    • Insert the pump bracket through the lower crossbar.
    • Secure the bracket with a rubber tipped nut.
    • Place the tire pump in the bracket.
결론
To disasemble your device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Garrett Goff
회원 가입일: 04/19/13
146 평판
안내서 1개 작성함
Cal Poly, Team 14-8, Maness Spring 2013 Cal Poly, Team 14-8, Maness Spring 2013 회원
CPSU-MANESS-S13S14G8
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 12
전체 시간: 1,243
