주요 콘텐츠로 건너뛰기
Frequency Amplifier Marshall Kilburn Battery Replacement
필요한 것
  1. Frequency Amplifier Marshall Kilburn Battery Replacement, Battery: 1 단계, 이미지 1/3 Frequency Amplifier Marshall Kilburn Battery Replacement, Battery: 1 단계, 이미지 2/3 Frequency Amplifier Marshall Kilburn Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Lay the amp on its side. You should see a small door kept closed with two screws. Turn the amp so the small door faces you.
  2. Frequency Amplifier Marshall Kilburn Battery Replacement: 2 단계, 이미지 1/1
    • Using a TR10 Torx Security Screwdriver, remove the two screws from the door.
    • Remove the door.
  3. Frequency Amplifier Marshall Kilburn Battery Replacement: 3 단계, 이미지 1/3 Frequency Amplifier Marshall Kilburn Battery Replacement: 3 단계, 이미지 2/3 Frequency Amplifier Marshall Kilburn Battery Replacement: 3 단계, 이미지 3/3
    • Pull the yellow tab to remove the battery from the amp.
  4. Frequency Amplifier Marshall Kilburn Battery Replacement: 4 단계, 이미지 1/2 Frequency Amplifier Marshall Kilburn Battery Replacement: 4 단계, 이미지 2/2
    • Carefully disconnect the battery cord from its socket. Carefully pinch the ends of the rectangular battery cord connector that is connected to the machine and gently pull the rectangular portion away from the machine so that it disconnects.
  5. Frequency Amplifier Marshall Kilburn Battery Replacement: 5 단계, 이미지 1/2 Frequency Amplifier Marshall Kilburn Battery Replacement: 5 단계, 이미지 2/2
    • To reassemble, plug in the new battery cord, and insert the battery pack; have the yellow tab repositioned as in step 3.
결론
Edith-Marie Roper
회원 가입일: 01/25/17
104 평판
안내서 1개 작성함
Washington State, Team 1-16, Staggers Spring 2017 Washington State, Team 1-16, Staggers Spring 2017 회원
WSU-STAGGERS-S17S1G16
1 회원
안내서 1개 작성하였습니다
댓글 한 개
Hi, my marshall kilburn will not charge my batterie, the (LL10) is fried on the platina. So i need a external charger for the battery but there are to many out there, which one do i need considering that i have to keep the original connector so i can connect it again to the kilburn socket. Thank you
Adnan Kasumovic - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 23
30일 전: 102
전체 시간: 4,231
