소개
This is a guide for replacing the battery for the Marshall Kilburn Portable Bluetooth Speaker. If the internal battery is broken or worn out, you can replace it with a new one.
필요한 것
Lay the amp on its side. You should see a small door kept closed with two screws. Turn the amp so the small door faces you.
댓글 한 개
Hi, my marshall kilburn will not charge my batterie, the (LL10) is fried on the platina. So i need a external charger for the battery but there are to many out there, which one do i need considering that i have to keep the original connector so i can connect it again to the kilburn socket. Thank you
