주요 콘텐츠로 건너뛰기
Frigidaire FFET1222QS Light Bulb Replacement
필요한 것
  1. Frigidaire FFET1222QS Light Bulb Replacement, Light Bulb: 1 단계, 이미지 1/3 Frigidaire FFET1222QS Light Bulb Replacement, Light Bulb: 1 단계, 이미지 2/3 Frigidaire FFET1222QS Light Bulb Replacement, Light Bulb: 1 단계, 이미지 3/3
    • Make sure to unplug the fridge from the wall socket before proceeding.
  2. Frigidaire FFET1222QS Light Bulb Replacement: 2 단계, 이미지 1/3 Frigidaire FFET1222QS Light Bulb Replacement: 2 단계, 이미지 2/3 Frigidaire FFET1222QS Light Bulb Replacement: 2 단계, 이미지 3/3
    • Using two hands, remove the plastic latch that's covering the dead light bulb.
    • To remove the latch, place both of your thumbs on the front face of the latch. Then, with your thumbs slowly push/squeeze the face of the latch, until the latch comes off.
  3. Frigidaire FFET1222QS Light Bulb Replacement: 3 단계, 이미지 1/3 Frigidaire FFET1222QS Light Bulb Replacement: 3 단계, 이미지 2/3 Frigidaire FFET1222QS Light Bulb Replacement: 3 단계, 이미지 3/3
    • Slowly unscrew the dead bulb in the counterclockwise direction to remove it from the socket.
  4. Frigidaire FFET1222QS Light Bulb Replacement: 4 단계, 이미지 1/3 Frigidaire FFET1222QS Light Bulb Replacement: 4 단계, 이미지 2/3 Frigidaire FFET1222QS Light Bulb Replacement: 4 단계, 이미지 3/3
    • Get the new light bulb and screw it into the empty bulb socket clockwise.
  5. Frigidaire FFET1222QS Light Bulb Replacement: 5 단계, 이미지 1/3 Frigidaire FFET1222QS Light Bulb Replacement: 5 단계, 이미지 2/3 Frigidaire FFET1222QS Light Bulb Replacement: 5 단계, 이미지 3/3
    • Plug the fridge back into the wall socket, then check if the light bulb is working.
  6. Frigidaire FFET1222QS Light Bulb Replacement: 6 단계, 이미지 1/2 Frigidaire FFET1222QS Light Bulb Replacement: 6 단계, 이미지 2/2
    • If the light bulb works, return the latch to its original position using your two hands.
    • When returning the latch make sure the latch’s front face is in the right direction.
    • Then slowly connect the latch to cover the new bulb and makes sure it is secured before closing the fridge door.
결론
Daniel kenneth
회원 가입일: 09/12/21
133 평판
안내서 1개 작성함
York University, Team 1-10, O'Regan Fall 2021 York University, Team 1-10, O'Regan Fall 2021 회원
YORK-O'REGAN-F21S1G10
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 75
전체 시간: 2,405
