주요 콘텐츠로 건너뛰기
Frigidaire FFHB2750TD6 Water Filter Replacement
  1. Frigidaire FFHB2750TD6 Water Filter  Replacement, Water Filter: 1 단계, 이미지 1/2 Frigidaire FFHB2750TD6 Water Filter  Replacement, Water Filter: 1 단계, 이미지 2/2
    • On the right inner side of the fridge, you will find the model number.
    • Identifying the correct model number will ensure the proper purchase of the new water filter.
  2. Frigidaire FFHB2750TD6 Water Filter  Replacement: 2 단계, 이미지 1/3 Frigidaire FFHB2750TD6 Water Filter  Replacement: 2 단계, 이미지 2/3 Frigidaire FFHB2750TD6 Water Filter  Replacement: 2 단계, 이미지 3/3
    • Click options on the control panel on the front of the left door.
    • Here it will say ice maker is on, click the minus button to turn it off.
    • You will hear a beeping sound to ensure that the ice maker is turned off.
  3. Frigidaire FFHB2750TD6 Water Filter  Replacement: 3 단계, 이미지 1/1
    • The water filter is in the upper right corner of the fridge.
  4. Frigidaire FFHB2750TD6 Water Filter  Replacement: 4 단계, 이미지 1/3 Frigidaire FFHB2750TD6 Water Filter  Replacement: 4 단계, 이미지 2/3 Frigidaire FFHB2750TD6 Water Filter  Replacement: 4 단계, 이미지 3/3
    • To remove the water filter turn it to the right until you feel it detach.
    • Then pull the filter straight out slowly from its slot.
    • Water may drip from the filter upon removal. Putting a towel underneath and removing products from that area will ensure an easy clean-up.
  5. Frigidaire FFHB2750TD6 Water Filter  Replacement: 5 단계, 이미지 1/2 Frigidaire FFHB2750TD6 Water Filter  Replacement: 5 단계, 이미지 2/2
    • Once the filter is removed, identify the model number on it.
    • The model number will ensure you buy the correct replacement at the store.
  6. Frigidaire FFHB2750TD6 Water Filter  Replacement: 6 단계, 이미지 1/2 Frigidaire FFHB2750TD6 Water Filter  Replacement: 6 단계, 이미지 2/2
    • Upon getting the new filter from the store install it into the fridge.
    • Insert the filter straight into its designated slot.
    • Twist the filter to the right until you feel and hear it click into place.
  7. Frigidaire FFHB2750TD6 Water Filter  Replacement: 7 단계, 이미지 1/2 Frigidaire FFHB2750TD6 Water Filter  Replacement: 7 단계, 이미지 2/2
    • To turn the icemaker back on click the options button and hit the minus button, it will beep indicating it is back on.
    • To reset the water filter you hit the down arrow button beneath the options button and go down to "water filter".
    • Press and hold the set button above the minus button on the right side, it will then say "good" next to the water filter.
    • Press options again to return to the main screen.
결론
Blake Mueller
회원 가입일: 03/17/21
160 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 27
30일 전: 96
전체 시간: 4,235
