주요 콘텐츠로 건너뛰기
Frigidaire FFHT2022AW Freezer Door Handle Replacement
필요한 것
  1. Frigidaire FFHT2022AW Freezer Door Handle Replacement, Freezer Door Handle: 1 단계, 이미지 2개 중 1개 Frigidaire FFHT2022AW Freezer Door Handle Replacement, Freezer Door Handle: 1 단계, 이미지 2개 중 2개
    • Remove the screws keeping the handle in place on the bottom face of the freezer door with a Phillips head screwdriver.
  2. Frigidaire FFHT2022AW Freezer Door Handle Replacement: 2 단계, 이미지 3개 중 1개 Frigidaire FFHT2022AW Freezer Door Handle Replacement: 2 단계, 이미지 3개 중 2개 Frigidaire FFHT2022AW Freezer Door Handle Replacement: 2 단계, 이미지 3개 중 3개
    • Remove any broken pieces of the original freezer handle.
    • Pushing up on any components attached to the handle mount connected to the bottom of the handle should remove anything still connected to the freezer.
    • Use caution when handling broken components.
  3. Frigidaire FFHT2022AW Freezer Door Handle Replacement: 3 단계, 이미지 2개 중 1개 Frigidaire FFHT2022AW Freezer Door Handle Replacement: 3 단계, 이미지 2개 중 2개
    • Tighten the handle mount at the top of the freezer in place if it is at all loose.
    • A bent mount may not allow the replacement handle to fully attach to the door. Replace this mount if it is missing or damaged.
  4. Frigidaire FFHT2022AW Freezer Door Handle Replacement: 4 단계, 이미지 2개 중 1개 Frigidaire FFHT2022AW Freezer Door Handle Replacement: 4 단계, 이미지 2개 중 2개
    • If the securing mounts at the top or bottom of the freezer handle are damaged, they will need to be removed.
    • Unscrew the old mount by twisting counterclockwise with a Phillips head screwdriver.
    • This model has replacement screws available for purchase.
  5. Frigidaire FFHT2022AW Freezer Door Handle Replacement: 5 단계, 이미지 2개 중 1개 Frigidaire FFHT2022AW Freezer Door Handle Replacement: 5 단계, 이미지 2개 중 2개
    • Screw in a new mount by twisting clockwise with a Phillips head screwdriver.
    • The handle mount needs space to properly attach to the handle. Leave some space between the flat part of the mount and the face of the freezer door.
  6. Frigidaire FFHT2022AW Freezer Door Handle Replacement: 6 단계, 이미지 2개 중 1개 Frigidaire FFHT2022AW Freezer Door Handle Replacement: 6 단계, 이미지 2개 중 2개
    • Secure a replacement handle in place by locking the mount in the top of the handle.
    • The mount should slide into a plastic guide on the top of the handle on the side that faces the freezer door.
  7. Frigidaire FFHT2022AW Freezer Door Handle Replacement: 7 단계, 이미지 2개 중 1개 Frigidaire FFHT2022AW Freezer Door Handle Replacement: 7 단계, 이미지 2개 중 2개
    • Align the two screw holes at the bottom of the replacement handle with the screw holes of the freezer door.
  8. Frigidaire FFHT2022AW Freezer Door Handle Replacement: 8 단계, 이미지 3개 중 1개 Frigidaire FFHT2022AW Freezer Door Handle Replacement: 8 단계, 이미지 3개 중 2개 Frigidaire FFHT2022AW Freezer Door Handle Replacement: 8 단계, 이미지 3개 중 3개
    • Secure the handle in place with two screws using a Phillips head screwdriver.
결승점
작성자
2다른 기여자 명과 함께
Kaitlyn B
회원 가입일: 02/22/24
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 223
