주요 콘텐츠로 건너뛰기
Frigidaire FFPE45B2QM Broken Hinge Replacement
필요한 것
  1. Frigidaire FFPE45B2QM Broken Hinge Replacement, Broken Hinge: 1 단계, 이미지 1/1
    • Carefully pop off the cover using a spudger or other opening tool.
  2. Frigidaire FFPE45B2QM Broken Hinge Replacement: 2 단계, 이미지 1/1
    • Use a JIS #1 screw driver to remove both 25mm bolts that are attaching the door to the refrigerator.
  3. Frigidaire FFPE45B2QM Broken Hinge Replacement: 3 단계, 이미지 1/2 Frigidaire FFPE45B2QM Broken Hinge Replacement: 3 단계, 이미지 2/2
    • Remove the damaged hinge. Make sure that you don't lose the bolt that goes into the door.
결론
Peterluchini
회원 가입일: 11/05/15
556 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-2, Bhusal Fall 2015 UMass Dartmouth, Team 1-2, Bhusal Fall 2015 회원
UMASSD-BHUSAL-F15S1G2
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
That might work on the TOP hinge, but on the bottom hinge the refrigerator would have to be tilted or laid on its side. Also, you could have used a hex socket of the appropriate size instead of the “JIS #1 screw driver“ to remove the bolts.
My refrigerator is a Whirlpool that uses top hinge bolts that require an allen wrench. The bottom is another can of worms, especially with the auto-close.
The previous Whirlpool model had a bottom hinge with a plastic / nylon piece to make it close. When it broke, I made an aluminum piece that kept the door closed.
doctordon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 486
