주요 콘텐츠로 건너뛰기
Frigidaire FFPE45B2QM Refrigerator Door Replacement
필요한 것
  1. Frigidaire FFPE45B2QM Refrigerator Door Replacement, Broken Hinge: 1 단계, 이미지 1/1
    • Carefully pop off the cover using a spudger or other opening tool.
  2. Frigidaire FFPE45B2QM Refrigerator Door Replacement: 2 단계, 이미지 1/1
    • Use a JIS #1 screw driver to remove both 25mm bolts that are attaching the door to the refrigerator.
  3. Frigidaire FFPE45B2QM Refrigerator Door Replacement: 3 단계, 이미지 1/2 Frigidaire FFPE45B2QM Refrigerator Door Replacement: 3 단계, 이미지 2/2
    • Remove the damaged hinge. Make sure that you don't lose the bolt that goes into the door.
  4. Frigidaire FFPE45B2QM Refrigerator Door Replacement, Refrigerator Door: 4 단계, 이미지 1/1
    • Remove the door by slowly lifting straight up, put the door off to the side.
  5. Frigidaire FFPE45B2QM Refrigerator Door Replacement: 5 단계, 이미지 1/1
    • Get a new, non-damaged door.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Peterluchini
회원 가입일: 11/05/15
556 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-2, Bhusal Fall 2015 UMass Dartmouth, Team 1-2, Bhusal Fall 2015 회원
UMASSD-BHUSAL-F15S1G2
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
So this is a 4.5 cubic foot mini-refrigerator. I suppose the door was damaged in moving the refrigerator - maybe dropped because it has a weight of 58 pounds.
doctordon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 1,443
