주요 콘텐츠로 건너뛰기
Frigidaire FPBS2778UF5 Drawer Handle Replacement
필요한 것
  1. Frigidaire FPBS2778UF5 Drawer Handle Replacement, Drawer Handle: 1 단계, 이미지 2개 중 1개 Frigidaire FPBS2778UF5 Drawer Handle Replacement, Drawer Handle: 1 단계, 이미지 2개 중 2개
    • This is what the handle looks like when it's loose or is about to fall off.
  2. Frigidaire FPBS2778UF5 Drawer Handle Replacement: 2 단계, 이미지 3개 중 1개 Frigidaire FPBS2778UF5 Drawer Handle Replacement: 2 단계, 이미지 3개 중 2개 Frigidaire FPBS2778UF5 Drawer Handle Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the four screws (two on each side) from beneath the handle using an Allen key.
    • You might need to press the Allen key hard inside for it to unscrew (if loosened).
  3. Frigidaire FPBS2778UF5 Drawer Handle Replacement: 3 단계, 이미지 2개 중 1개 Frigidaire FPBS2778UF5 Drawer Handle Replacement: 3 단계, 이미지 2개 중 2개
    • Make sure the nuts holding the handle are secure. Only use your hands to tighten them, as using a wrench might damage the fridge.
  4. Frigidaire FPBS2778UF5 Drawer Handle Replacement: 4 단계, 이미지 3개 중 1개 Frigidaire FPBS2778UF5 Drawer Handle Replacement: 4 단계, 이미지 3개 중 2개 Frigidaire FPBS2778UF5 Drawer Handle Replacement: 4 단계, 이미지 3개 중 3개
    • Ensure that the nuts are securely inside the handle. Keep them inside the entire time to make the process easier.
    • Make sure nothing is inside on both sides of the handle which may have been causing it to loosen up.
  5. Frigidaire FPBS2778UF5 Drawer Handle Replacement: 5 단계, 이미지 2개 중 1개 Frigidaire FPBS2778UF5 Drawer Handle Replacement: 5 단계, 이미지 2개 중 2개
    • Clean the inside with cotton swabs to prevent future problems.
    • This step is optional.
  6. Frigidaire FPBS2778UF5 Drawer Handle Replacement: 6 단계, 이미지 3개 중 1개 Frigidaire FPBS2778UF5 Drawer Handle Replacement: 6 단계, 이미지 3개 중 2개 Frigidaire FPBS2778UF5 Drawer Handle Replacement: 6 단계, 이미지 3개 중 3개
    • Loosen the nuts on both sides until they are not seen inside.
    • This will keep the holder stable on the fridge when it's screwed in.
  7. Frigidaire FPBS2778UF5 Drawer Handle Replacement: 7 단계, 이미지 3개 중 1개 Frigidaire FPBS2778UF5 Drawer Handle Replacement: 7 단계, 이미지 3개 중 2개 Frigidaire FPBS2778UF5 Drawer Handle Replacement: 7 단계, 이미지 3개 중 3개
    • Correctly place the holder in the correct holes on both sides.
    • Hold the holder and press it firmly onto the fridge to keep it steady.
    • You may require another person for this step.
    • Start screwing it back in with the same Allen key.
  8. Frigidaire FPBS2778UF5 Drawer Handle Replacement: 8 단계, 이미지 2개 중 1개 Frigidaire FPBS2778UF5 Drawer Handle Replacement: 8 단계, 이미지 2개 중 2개
    • Make sure the screws are tight.
결승점
작성자
1다른 기여자 명과 함께
Parth Gupta
회원 가입일: 01/09/24
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 131
