주요 콘텐츠로 건너뛰기
Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement
필요한 것
  1. Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Unplug your refrigerator: 1 단계, 이미지 1개 중 1개
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Remove the light bulb: 2 단계, 이미지 3개 중 1개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Remove the light bulb: 2 단계, 이미지 3개 중 2개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Remove the light bulb: 2 단계, 이미지 3개 중 3개
    • Open the refrigerator door.
    • Unscrew the light bulb on the rear of the control housing.
  3. Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Unfasten the control housing: 3 단계, 이미지 3개 중 1개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Unfasten the control housing: 3 단계, 이미지 3개 중 2개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Unfasten the control housing: 3 단계, 이미지 3개 중 3개
    • Use a 1/4" nut driver to remove the two 1/4" hex head fasteners, securing the control housing.
    • Use a 1/4" nut driver to remove the three additional 1/4" hex head fasteners, securing the control housing.
  4. Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Reposition the control housing: 4 단계, 이미지 3개 중 1개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Reposition the control housing: 4 단계, 이미지 3개 중 2개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Reposition the control housing: 4 단계, 이미지 3개 중 3개
    • Lower the control housing, allowing the rear portion to stay closer to the top of the fresh food compartment.
    • Support the control housing with your hand until the right hand corner rests on one of the shelves
  5. Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Disconnect the control housing: 5 단계, 이미지 2개 중 1개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Disconnect the control housing: 5 단계, 이미지 2개 중 2개
    • Disconnect the control housing by squeezing the locking tab on the connector and pulling the connector downward.
    • Support the end of control housing nearest the cable with one hand.
  6. Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement: 6 단계, 이미지 3개 중 1개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement: 6 단계, 이미지 3개 중 2개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement: 6 단계, 이미지 3개 중 3개
    • Locate the auxiliary connector and unclip it from the control housing. You may need to push the clip tabs out of the way with a finger.
    • Disconnect the auxiliary connector by squeezing the locking tab and pulling the connector halves apart.
  7. Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Locate fresh food thermistor: 7 단계, 이미지 3개 중 1개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Locate fresh food thermistor: 7 단계, 이미지 3개 중 2개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Locate fresh food thermistor: 7 단계, 이미지 3개 중 3개
    • Locate the fresh food thermistor and peel the tan tape to release the wiring.
  8. Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Free the fresh food thermistor: 8 단계, 이미지 3개 중 1개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Free the fresh food thermistor: 8 단계, 이미지 3개 중 2개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Free the fresh food thermistor: 8 단계, 이미지 3개 중 3개
    • Use your fingers to free the thermistor by pulling it out of the bracket securing it to the control housing.
  9. Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Unfasten the damper assembly: 9 단계, 이미지 3개 중 1개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Unfasten the damper assembly: 9 단계, 이미지 3개 중 2개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Unfasten the damper assembly: 9 단계, 이미지 3개 중 3개
    • With your fingers, remove the beige masking tape securing the damper assembly to the control housing.
  10. Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Lift the damper assembly: 10 단계, 이미지 2개 중 1개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Lift the damper assembly: 10 단계, 이미지 2개 중 2개
    • Lift the damper assembly upward to access the tape holding the freezer thermistor.
  11. Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Release the freezer thermistor: 11 단계, 이미지 3개 중 1개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Release the freezer thermistor: 11 단계, 이미지 3개 중 2개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Release the freezer thermistor: 11 단계, 이미지 3개 중 3개
    • Use your fingers to peel the blue tape securing the freezer thermistor.
  12. Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Free the freezer thermistor: 12 단계, 이미지 3개 중 1개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Free the freezer thermistor: 12 단계, 이미지 3개 중 2개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Free the freezer thermistor: 12 단계, 이미지 3개 중 3개
    • Grasp the freezer thermistor and pull it away from the foam damper assembly on the control housing to free the freezer thermistor from its location.
  13. Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Release the thermistor leads from the harness clip: 13 단계, 이미지 2개 중 1개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Release the thermistor leads from the harness clip: 13 단계, 이미지 2개 중 2개
    • Unclip the thermistor leads.
    • This applies to both the fresh food and freezer thermistor leads. In both cases they are white 2-conductor cords.
  14. Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Disconnect the thermistors: 14 단계, 이미지 3개 중 1개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Disconnect the thermistors: 14 단계, 이미지 3개 중 2개 Frigidaire Side-By-Side Refrigerator Fresh Food Thermistor Replacement, Disconnect the thermistors: 14 단계, 이미지 3개 중 3개
    • Disconnect the thermistors from the control board by squeezing the locking tab on the connector and pulling the connector out of the socket on the control board.
    • The thermistors share one connector on the control board, and they are not sold as individual parts but as an assembly.
    • You can peel the tape on the harness or cut it carefully to release the thermistor wires from the harness.
    • You can use a cable tie in place of the tape to secure the harness if needed afterward.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
작성자
1다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
38,497 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,623개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 18
전체 시간: 295
