주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Front Inner Tube Replacement
  1. Front Inner Tube Replacement, Front Inner Tube: 1 단계, 이미지 2개 중 1개 Front Inner Tube Replacement, Front Inner Tube: 1 단계, 이미지 2개 중 2개
    • First, remove the front wheel from the frame by unscrewing the adjustable screw
  2. Front Inner Tube Replacement: 2 단계, 이미지 3개 중 1개 Front Inner Tube Replacement: 2 단계, 이미지 3개 중 2개 Front Inner Tube Replacement: 2 단계, 이미지 3개 중 3개
    • Next, wedge tire tool below the bike wheel, right above the rim.
    • Once firmly in place, push the tire tool down towards the ground in order to create spacing between the tire and the rim.
    • Following this, grab the 2nd tire tool and place it into the gap you have created.
    • Slide the 2nd tool around the entire circumference of the tire, while holding the first in place, in order to dislodge the tire from the rim.
  3. Front Inner Tube Replacement: 3 단계, 이미지 2개 중 1개 Front Inner Tube Replacement: 3 단계, 이미지 2개 중 2개
    • After removing the bike tire, locate the bike valve used to pump air into the tire.
    • Gently remove the inner tube starting with the area around the valve.
    • Make a note of where the hole for the valve is located on the bike rim, because that is where the next step begins.
  4. Front Inner Tube Replacement: 4 단계, 이미지 1개 중 1개
    • Pump a small amount of air into the new bike tube so that it is easier to work with.
    • Next, locate the hole in the bike rim and feed the valve through and into position.
    • Next, wrap the rest of the tubing over the rim comfortably, while making sure that no folds or creases form on the tube.
  5. Front Inner Tube Replacement: 5 단계, 이미지 2개 중 1개 Front Inner Tube Replacement: 5 단계, 이미지 2개 중 2개
    • Finish by placing the bike tire back on the the frame, while making sure that no fold or creases form in the tube.
    • Lastly, pump air into the tire and remount onto bike frame.
결론
To reassemble your device, follow these instructions.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Theo Tzeng
회원 가입일: 07/22/13
59 평판
안내서 1개를 작성함
UC Santa Barbara, Team 1-2, Bradley Spring 2013 UC Santa Barbara, Team 1-2, Bradley Spring 2013 회원
UCSB-BRADLEY-S13S1G2
4 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 15
지난 30일: 42
전체 시간: 2,732
