소개
We're going to replace the batteries in a singing doll. This one happens to be Elsa, but this guide is applicable to many plush dolls that sing!
필요한 것
Carefully arrange Elsa's clothing so her body is accessible.
Find the Voice Module inside the toy's body.
Using a seam ripper, open Elsa up near the Voice Module.
Once the seam is ripped, you'll be able to retrieve the Voice Module from inside the toy.
Carefully pry off the top the Voice Module to expose the electronics inside.
Carefully remove the worn LR41 batteries from the Voice Module electronics.
Replace with new LR41s, obviously!
To reassemble Elsa, follow these instructions in reverse order. Except instead of ripping seams, sew them back up.
Be especially careful to sew securely -- loose batteries are a choking hazard.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
my daughter lost an Elsa like this a long time ago, would you mind sharing the name of this product or where you bought it from? Thanks
