주요 콘텐츠로 건너뛰기
Fugoo Style XL Speaker Replacement
필요한 것
  1. Fugoo Style XL Speaker Replacement, Fabric Case: 1 단계, 이미지 1/2 Fugoo Style XL Speaker Replacement, Fabric Case: 1 단계, 이미지 2/2
    • Using your hand, unscrew the large screws underneath the speaker.
  2. Fugoo Style XL Speaker Replacement: 2 단계, 이미지 1/3 Fugoo Style XL Speaker Replacement: 2 단계, 이미지 2/3 Fugoo Style XL Speaker Replacement: 2 단계, 이미지 3/3
    • Using your hand, gently lift the large plastic tab secured to the rubber holding.
    • After lifting the tab, slide the speaker out of its case.
    • Ensure the tab is lifted only slightly above the rubber holding. Bending the plastic tab too far could result in damage to the case.
  3. Fugoo Style XL Speaker Replacement, Speaker: 3 단계, 이미지 1/2 Fugoo Style XL Speaker Replacement, Speaker: 3 단계, 이미지 2/2
    • There are 8 screws (4 on each side) holding covers that conceal the bass speakers. Remove these 3mm screws using a #2.0 Hex screwdriver.
  4. Fugoo Style XL Speaker Replacement: 4 단계, 이미지 1/2 Fugoo Style XL Speaker Replacement: 4 단계, 이미지 2/2
    • Using your hand, pull the covers away from the speaker.
  5. Fugoo Style XL Speaker Replacement: 5 단계, 이미지 1/2 Fugoo Style XL Speaker Replacement: 5 단계, 이미지 2/2
    • Using a #2.0 Hex screwdriver to unscrew the 8 12mm screws depicted.
  6. Fugoo Style XL Speaker Replacement: 6 단계, 이미지 1/2 Fugoo Style XL Speaker Replacement: 6 단계, 이미지 2/2
    • Gently pull apart the front casing from the back casing.
    • Speakers on the front casing have wires directly connected to the motherboard. Pulling off the casing with force will result in damage.
  7. Fugoo Style XL Speaker Replacement: 7 단계, 이미지 1/2 Fugoo Style XL Speaker Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using a pair of tweezers or your hand, carefully remove the red bundled cable connectors from the motherboard.
  8. Fugoo Style XL Speaker Replacement: 8 단계, 이미지 1/3 Fugoo Style XL Speaker Replacement: 8 단계, 이미지 2/3 Fugoo Style XL Speaker Replacement: 8 단계, 이미지 3/3
    • Each speaker is attached to the casing with 3mm screws. Remove the screws using a #2.0 Hex screwdriver.
    • Once the screws are removed, carefully lift the speaker from the casing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
James Gifford
회원 가입일: 09/25/17
573 평판
안내서 5개 작성하였습니다
USF Tampa, Team S3-G4, Cannon Fall 2017 USF Tampa, Team S3-G4, Cannon Fall 2017 회원
USFT-CANNON-F17S3G4
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Hello James,
Nice work. But where can I find the replacement speaker?! Best Regards
Andre Costa - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 14
전체 시간: 770
