필요한 것
Begin by unscrewing the four 10.72mm corner screws using the h2.0 screw driver.
Using the h1.5 screwdriver and remove remaining six 5.79mm screws on the front of the speaker.
Pull front part of shell away from back part of shell.
Change to the h1.3 head. Remove all 4-5.57mm screws on both speaker covers
Pull on the speaker covers, thus removing them
Rotate to side the speaker that has the charging port. Remove the 4-5.57mm screws of the facing you.
Rotate the speaker 180 degrees and then remove 4-5.57 screws on the side speaker that has the power/bluetooth buttons
The circuit board will be revealed, you will notice the various individual speaker connections to the circuit board.
Remove blue "clip" from the circuit board.
From this point, pull the side panel off gently, exposing the charging port.
At this time, you can remove the charging port and replace it.
