주요 콘텐츠로 건너뛰기
Fuijifilm X20 Viewfinder Replacement
필요한 것
  1. Fuijifilm X20 Viewfinder Replacement, Removing the existing viewfinder: 1 단계, 이미지 2개 중 1개 Fuijifilm X20 Viewfinder Replacement, Removing the existing viewfinder: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using a small Philips screwdriver remove the 2 screws at the side of the viewfinder.
    • With a pair of tweezers or an X-acto knife, remove the piece of tape on the other side of the viewfinder.
  2. Fuijifilm X20 Viewfinder Replacement, Installing a new viewfinder: 2 단계, 이미지 2개 중 1개 Fuijifilm X20 Viewfinder Replacement, Installing a new viewfinder: 2 단계, 이미지 2개 중 2개
    • Before installing a new viewfinder, fully extend the lens as shown in the picture.
    • For reference, the 2nd picture shows the tracks for the guiding pins of the viewfinder in this position.
    • You can then mount the viewfinder and follow step 1 in reverse to wrap up the replacement.
결론
That wraps it up, hope this prevents someone else from breaking their lens guide pins.
작성자
2다른 기여자 명과 함께
Joost Mertens
회원 가입일: 06/09/21
85 평판
안내서 1개를 작성함
1가이드 댓글
Hi Joost Mertens,
Do you know anyone who would do this for me?
Thank you.
Mikefatica@yahoo.com
Mike Fatica - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 31
전체 시간: 2,377
