주요 콘텐츠로 건너뛰기
FujiFilm FinePix A340 Flash Unit Replacement
필요한 것
  1. FujiFilm FinePix A340 Flash Unit Replacement, Outer Case: 1 단계, 이미지 1/1
    • To prevent the danger of electric shock, remove the batteries before continuing to the next steps.
    • Slide the battery cover to the side to release the batteries.
  2. FujiFilm FinePix A340 Flash Unit Replacement: 2 단계, 이미지 1/3 FujiFilm FinePix A340 Flash Unit Replacement: 2 단계, 이미지 2/3 FujiFilm FinePix A340 Flash Unit Replacement: 2 단계, 이미지 3/3
    • Remove five screws from the camera casing using a tri-point Y0 screwdriver.
  3. FujiFilm FinePix A340 Flash Unit Replacement: 3 단계, 이미지 1/2 FujiFilm FinePix A340 Flash Unit Replacement: 3 단계, 이미지 2/2
    • Grab the case with your hands and slowly pull back the outer casing.
  4. FujiFilm FinePix A340 Flash Unit Replacement, LCD Screen: 4 단계, 이미지 1/1
    • Locate the LCD screen and anchoring screw.
    • Remove screw.
  5. FujiFilm FinePix A340 Flash Unit Replacement: 5 단계, 이미지 1/1
    • Carefully pull the LCD screen away from the board it is connected to.
  6. FujiFilm FinePix A340 Flash Unit Replacement: 6 단계, 이미지 1/1
    • Push both blue switches away from the holding device to unleach lcd ribbon.
    • Be careful when removing ribbon. If you damage it, you will need to replace it as well.
  7. FujiFilm FinePix A340 Flash Unit Replacement: 7 단계, 이미지 1/1
    • Carefully detach the ribbon from where it was connected by the blue pins.
  8. FujiFilm FinePix A340 Flash Unit Replacement: 8 단계, 이미지 1/1
    • Now that everything has been disconnected from the board, remove LCD screen.
  9. FujiFilm FinePix A340 Flash Unit Replacement, Motherboard: 9 단계, 이미지 1/1
    • Remove the two screws holding the circuit board down.
  10. FujiFilm FinePix A340 Flash Unit Replacement: 10 단계, 이미지 1/2 FujiFilm FinePix A340 Flash Unit Replacement: 10 단계, 이미지 2/2
    • Remove black sticky tape from circuit board and camera case.
  11. FujiFilm FinePix A340 Flash Unit Replacement: 11 단계, 이미지 1/2 FujiFilm FinePix A340 Flash Unit Replacement: 11 단계, 이미지 2/2
    • Gently pull the circuit board away from the front side of the camera.
    • Be careful when removing assembly as to not break any solder leads or damage lens assembly.
  12. FujiFilm FinePix A340 Flash Unit Replacement: 12 단계, 이미지 1/2 FujiFilm FinePix A340 Flash Unit Replacement: 12 단계, 이미지 2/2
    • Remove the logic board by pulling straight away from assembly.
  13. FujiFilm FinePix A340 Flash Unit Replacement, Flash Unit: 13 단계, 이미지 1/1
    • Locate the flash unit of the camera. It includes the camera's flash and a capacitor.
  14. FujiFilm FinePix A340 Flash Unit Replacement: 14 단계, 이미지 1/2 FujiFilm FinePix A340 Flash Unit Replacement: 14 단계, 이미지 2/2
    • Unsolder the flash unit at it's three points.
    • Be careful not to damage the circuit board or surrounding parts with the solder iron.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cody
회원 가입일: 04/18/10
47 평판
안내서 4개 작성하였습니다
Cal Poly, Team 7-11, Maness Spring 2010 Cal Poly, Team 7-11, Maness Spring 2010 회원
CPSU-MANESS-S10S7G11
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 3,919
