주요 콘텐츠로 건너뛰기
FujiFilm FinePix S4500 Flash Springs Replacement
필요한 것
  1. FujiFilm FinePix S4500 Flash Springs Replacement, LCD: 1 단계, 이미지 1/1
    • Remove the two 3.5 mm Phillips #1 screws in these positions on the left side of the camera with a screwdriver.
  2. FujiFilm FinePix S4500 Flash Springs Replacement: 2 단계, 이미지 1/1
    • Remove the three 3.5 mm Phillips #1 screws in these locations on the bottom of the camera with a screwdriver.
  3. FujiFilm FinePix S4500 Flash Springs Replacement: 3 단계, 이미지 1/1
    • Remove the four 3.5 mm Phillips #1 screws in these positions on the right side of the camera with a screwdriver.
  4. FujiFilm FinePix S4500 Flash Springs Replacement: 4 단계, 이미지 1/1
    • Use a plastic opening tool to separate the back panel from the camera on the left side.
  5. FujiFilm FinePix S4500 Flash Springs Replacement: 5 단계, 이미지 1/1
    • Use a plastic opening tool to separate the back panel from the camera on the bottom.
  6. FujiFilm FinePix S4500 Flash Springs Replacement: 6 단계, 이미지 1/2 FujiFilm FinePix S4500 Flash Springs Replacement: 6 단계, 이미지 2/2
    • Use a plastic opening tool to separate the back panel from the camera on the left side, then remove the back panel from the camera.
  7. FujiFilm FinePix S4500 Flash Springs Replacement: 7 단계, 이미지 1/1
    • Use a plastic opening tool to separate the LCD screen from the camera.
  8. FujiFilm FinePix S4500 Flash Springs Replacement: 8 단계, 이미지 1/2 FujiFilm FinePix S4500 Flash Springs Replacement: 8 단계, 이미지 2/2
    • Flip up the black tab holding the LCD ribbon wire in place and remove wire.
  9. FujiFilm FinePix S4500 Flash Springs Replacement, Flash Springs: 9 단계, 이미지 1/3 FujiFilm FinePix S4500 Flash Springs Replacement, Flash Springs: 9 단계, 이미지 2/3 FujiFilm FinePix S4500 Flash Springs Replacement, Flash Springs: 9 단계, 이미지 3/3
    • Remove the 3.5 mm Phillips #1 screws holding the top to allow access to the flash mechanism.
  10. FujiFilm FinePix S4500 Flash Springs Replacement: 10 단계, 이미지 1/1
    • Remove the top and use a screwdriver to remove the highlighted 2.7 mm Phillips #1 screws.
    • Remove the top cover of the flash.
  11. FujiFilm FinePix S4500 Flash Springs Replacement: 11 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the pins holding the flash mechanism in place. Tweezers may be required.
  12. FujiFilm FinePix S4500 Flash Springs Replacement: 12 단계, 이미지 1/1
    • Use a pair of tweezers to remove the flash mechanism springs , then replace with the new springs.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Vicente Rios
회원 가입일: 01/25/17
708 평판
안내서 6개 작성하였습니다
Cal Poly, Team 9-4, Banghart Winter 2017 Cal Poly, Team 9-4, Banghart Winter 2017 회원
CPSU-BANGHART-W17S9G4
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 695
