주요 콘텐츠로 건너뛰기
FujiFilm FinePix S5100 Back Cover Replacement
필요한 것
  1. FujiFilm FinePix S5100 Back Cover Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure your camera is in the off position.
    • Orient the camera upside down with the lens facing to the left and the battery compartment facing directly toward you.
    • Open the battery door by pushing down and in the direction of the arrow on the door.
  2. FujiFilm FinePix S5100 Back Cover Replacement: 3 단계, 이미지 1/1
    • Remove four AA batteries from the camera.
  3. FujiFilm FinePix S5100 Back Cover Replacement, Back Cover: 4 단계, 이미지 1/1
    • Turn the camera so the screen is facing you and the camera lens is facing away from you.
  4. FujiFilm FinePix S5100 Back Cover Replacement: 5 단계, 이미지 1/3 FujiFilm FinePix S5100 Back Cover Replacement: 5 단계, 이미지 2/3 FujiFilm FinePix S5100 Back Cover Replacement: 5 단계, 이미지 3/3
    • Remove two 0.9mm Phillips #000 screws from the right side of the camera.
    • Remove one 0.6mm Phillips #000 screw from the left side of the camera.
    • Remove two 0.6mm Phillips #000 screws from the bottom side of the camera.
    • When replacing the back cover on the camera, there will be an audible click which ensures the cover has completely seated with the rest of the camera.
  5. FujiFilm FinePix S5100 Back Cover Replacement: 6 단계, 이미지 1/3 FujiFilm FinePix S5100 Back Cover Replacement: 6 단계, 이미지 2/3 FujiFilm FinePix S5100 Back Cover Replacement: 6 단계, 이미지 3/3
    • Carefully pull the back cover and separate it from the rest of the camera body.
    • Carefully flip up the top of the tan colored tab to disconnect the ribbon cable and completely remove the back cover.
결론
Kristen Gismondi
회원 가입일: 11/12/14
84,800 평판
안내서 215개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,876개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 197
